well RB25DE it seems to work well, i have a fuel consumption improvement as well as throttle response improvement, also with a fuel filter change/ If u do it properly by taking them out i think they just use compress air and detergents, im not sure. If u get ur car serviced sumwhere they should be able to do ur injectors
https://www.sau.com.au/forums/topic/16937-injector-cleaning/#findComment-349723
Check the Yellow Pages under "Fuel Injection" and you'll find some people who will come to you. You really should have them properly cleaned, but then use the shop stuff (Nulon and STP(?) are probably the best) to keep them in shape.
It is possible to remove/refit them yourself, just takes a bit of patience.
https://www.sau.com.au/forums/topic/16937-injector-cleaning/#findComment-349832
haha, i tried to remove one of my injectors a while back, gave up after trying to twist them out.. didn't really want to break one so i left it be.
I remember in my old car i was charged $200 for an injector clean, and not even sure whether they took them out and cleaned them properly (doubt it).. so just be careful you don't get ripped.
I tried some Wyns injector cleaner, didn't seem to do much in my skyline - not visible anyway.
https://www.sau.com.au/forums/topic/16937-injector-cleaning/#findComment-349879
yeah thats right i tried the Nulon $10 thingy a while back and did not really feel any difference:(
i dont know how difficult it is to take the injectors out. guess ill have to try and have a look.
i was told that there is a method where they (the pro) plumb this special treatment fluid into the fuel line and run the car for something like 20 min.??? and this will cost around $200
also i spoke to a mechanic a while back he said that using an ultrasonic cleaner is probably the best way.
mmm not sure which way to go.
ron
https://www.sau.com.au/forums/topic/16937-injector-cleaning/#findComment-349993
One of the best on the market is Redline SI-1 Cleaner. I would give that a shot. Its ~18 bucks. Its not your typical solvent style cleaner (heat activated detergent) so it wont clean out your petrol tank aswell.. go to www.redlineoil.com to get some more info about it..
If you cant find it, Nulons Total Fuel System Cleaner works well too.
https://www.sau.com.au/forums/topic/16937-injector-cleaning/#findComment-350283
You can't use compressed air to clean injectors, the holes are way too small. The only way to do it aside from fuel additives in your tank is with a special injector cleaning machine that uses ultrasonic sound waves to rattle the built-up particles free.
Try the bottled injector cleaner first, if that doesn't seem to work or not do much, fork over the $200 for the professional clean. Make sure you go to a reputable workshop. I had my Commodore's done, was quoted around $220 before I took it in, but when given the bill I saw I was slapped another couple of hours labour on top for removing and refitting. I could have them in and out in under half an hour.
https://www.sau.com.au/forums/topic/16937-injector-cleaning/#findComment-353624
Ron
The effect of the fuel injector cleaner will depend on the condition of your fuel system.If injectors are dirty,then you may feel an improvement.But if they are clean already to begin with,naturaly there will be no benefit from using an injector cleaner.
https://www.sau.com.au/forums/topic/16937-injector-cleaning/#findComment-353898
A mechanic I knew once did some tests himself on injector cleaning products. His findings were that adding 1 litre of methylated spirits to a full tank was more effective than any product he used (typical off the shelf products).
Best result I saw myself was this guys EB falcon was running like crap, and he tried the wynns (spelling) stuff with no effect. After running 1 litre of metho in the car, and thrashing the crap out of it, it was much smoother, and fuel ecomony was slightly better, which indicated that the metho did the trick.
Still better to get them taken out and cleaned properly.
When I had mine cleaned in my last car (N/A R31) the only difference I niticed was improved economy...
https://www.sau.com.au/forums/topic/16937-injector-cleaning/#findComment-359067
My 2c,
I had my injectors professionally cleaned when we were troubleshooting a missfire. Definitely could feel the difference after cleaning. Improved economy, more of the throw-ya-back-in-your-seat feel :P. I haven't used the off the shelf products, so I can't really comment on them.
The injectors in an RB20 are held in using thin wire clips (U-shaped). Pull the clip off and the plug comes straight off. To put them back on, put the plug on first and then push the clip into place.
Michael
https://www.sau.com.au/forums/topic/16937-injector-cleaning/#findComment-359347
No side effect to turbo engines with injector cleaner or metho, because your turbo doesn't touch any of it. The only thing you have to be worried about is changing the octane of your fuel, but in such small doses that's not going to happen.
https://www.sau.com.au/forums/topic/16937-injector-cleaning/#findComment-359400
Originally posted by JimX
Could have been running like crap (at least partially) because of water.
Nah, it was running like crap for a while (months) not just the last tank....
If you use metho, make sure you go for a few long hard drives, as the metho itself can evaoporate. So if you add the 1 litre to a full tank, make sure you go though that tank in less than a week.
If your worried about octane levels, add octane booster before you add metho. It can only help...
https://www.sau.com.au/forums/topic/16937-injector-cleaning/#findComment-360959
yo ron... i just got my injectors cleaned for $22 each.... there is a place in Lidcombe 13/2 railway pde lidcomb its called AFI they specialise in cleaning injectors and all sorts of fuel stuff man...
i went there in person and hte dude said $16.50 but then told me that was trade price... kient so if u say ur from like a business then u get trade price....
if u want it done let me know man i will try get my mates performance company to get it done by them for trade price...
https://www.sau.com.au/forums/topic/16937-injector-cleaning/#findComment-366959
    • @soviet_merlin Thanks mate!  Nothing too major but will hold me up for a while. I've got lymphomas to get taken off the back of my neck and the middle of my spine which always conjures scary thoughts!  It sounds worse than it is. Yeah great, conjuring more rabbit hole deepening , just what I need! 🤣
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
