After A Particularly Bad Week - Something Has Cheered Me Up...
Autobots - transform!
Latest trailer with ALL KINDS of energon fueled goodness including some neato airborn transforming trickey by Starscream.
http://www.autoblog.com/2007/05/17/transfo...-trailer-debuts
And, of course - a revisit to Juz's favourite My Little Pony :)
I hope it's as good as it deserves to be.
My only fault so far is that Bumblebee is not a bug, but a GM car.
I know that they gotta save costs where they can, but c'mon.
too bad this means that there will be no Mirage (F1 car), Hound(Jeep), Wheeljack (Lancia, I think) or Sunstreaker (Lamborghini).
You know, I'm probably nerdy enough to try and get some autobot badges made to put on my R32.
I've stopped watching all the trailers as I'm waiting for the movie to come out and don't want to spoil it.
Bring on July 4th already! :)
There was a poster at Village Cinema, saying its coming out on 28/06/07.
We get the movie before America?
Ive seen some transformers stickers appearing on import cars already haha
Man, I'm so hanging for this!
I even went over to my Dads the other weekend to find my box of G1 Transformers & bring it home, all packed up tight some with their original packaging.
Yes.... Im a geek, I know.....
well i was keen to see this when they released the original teaser...
but then i saw this...
a MICHAEL BAY film
and then i shunned it... and now... seeing the cast... its gone back to the back of the movie list of movies i want to see.
And yeah... not making Bumble Bee a bug... is about as gay as as gay can be
oh yeh is that rodimus prime or optimus?? i liked optimus better.
rodimus was a hotrod not a truck.
your thinking of Ultramagnus the other truck im assuming... was a car transport type of truck who took over when Optimus died
A quick check on wiki showed that VW and Porsche did not want to be involved with transformers at all, as they didn't want to be involved in "War toys" Apparently VW were happy to make Engines for Hitler, but not for robots that save the world.
So it seems that the evil GM might have just been a means to an end.
I'm kind of surprised they didn't make starscream into a MiG-27 or something, instead of an F-22 (to replace the original F-15 that all the "seekers" were) because as American movies teach us, American planes are only used by the good guys!
Still. Wish there was an R-34 transformer.
It's funny though. Transformers, technologically advanced aliens. Pretending to be American muscle cars with all the engineering of a toaster.
Ni - Normally I'd point and scream out 'geek!' - but I know exactly what you are talking about so I'll just stay quiet.
:D everyone loved transformers as a kid... wish i kept all mine. Think the only one i have left is Grimlock
"Grimlock angry!"
"Grimlock destroy!"
lol how sad.
HAHAHAHA
Double HAHAHAHA
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
