Hey guys, cleaning out my closet..
PICK UP ONLY.....I'M IN CANBERRA - 7x10's postage at buyers cost
Kenwood 7x10's are used, only for less than a month. basically new. bought for $220. Will sell for $159 ono
5 way, 90 watt RMS.
Tv is 68cm. It works pretty good. although picture is a little slanted only in the bottom left side. - Scart input, comes with RCA adapter thingie - $20 ono
Rowing Machine: Was bought with broken cover quite a while ago. Only used a couple of times as i got quite lazy.... Still works 100%, cover is broken, has a large crack. Probably be able to fix with some good glue :). Computer part runs on batteries. $170 ono
Computer: -$200 ono
MAKE AN OFFER
You more than welcome to come have a look as well. Just PM me.
Dan
Edited by 33Sedan
https://www.sau.com.au/forums/topic/169371-fs-68cm-tv-50ono-rowing-machine-200/
Tv is 68cm. It works pretty good. although picture is a little slanted only in the bottom left side. - Scart input, comes with RCA adapter thingie - $90 ono
Computer: -$220 ono
AMD 1.8ghz
512mb Ram
a few hard drives(3) in there - a little more than 100gb
Dual layer dvd burner
cd burner
geforce 440mx 64mb graphics card
no sound card
Lan card
I started it up and it worked fine. Had xp pro on it but found it had to be activated then realised im running it on my other pc so wouldn't have a OS unless u wanted to crack it ;-)
I'm sure theres something important I'm missing but oh well. Ask questions
MAKE AN OFFER
Daniel
$150 for the p/c
  • 3 weeks later...
  • 3 months later...
    • I agree on doing some better than factory pistons, rods, and oil pump. For anyone using the vehicle on the road, I don't get why everyone wants big cams. The stock cam profile, with some more lift would be mint for road usage. Everyone going big cams and then wondering why it isn't as responsive in traffic, when they've shifted the torque curve upwards an additional 1000RPM. Make torque, at lower RPM. Sure it's not as cool as claiming "500KW" and revving it to 8,0000RPM, but that same torque 2,000RPM earlier... Then you don't need the extremely high end pistons and rods, and blah blah blah.
    • Personal experience. Those f**kers burn. And are actually a PITA to put out. Next time I walk down the back, I'll snap a photo of what the inside of the bonnet looks like when that thing ignites. PS, powder fire extinguishers are useless on that stuff too as it's fibrous and when it ignites, it starts to pull apart. And you end up just blowing powder through a sieve effectively.   Like the big thing is, if it's fire resistant, it's job is to stop what burning? The METAL above it? It's just to try keep heat off the bonnet paint work.
    • Oh man, sorry, $60.00000000... 😛
    • That's more or less what he meant. What it really means is that you do not have to go full crazy on the build. Don't need the best oil pump, expensive rods & pistons, big cams, etc. You can upgrade whatever you want instead of using stock level items, but you don't have to. Having said that - any time an RB is opened up, if anything is getting replaced, I think the opportunity should be taken to do all the sensible upgrades. Pistons, rods, pump, etc.
    • February update 🙂 We managed to get the very last 1/18th "Extra Scale" cars stock available from bookstores in Kyoto. These are actually the last ones and will not be restocked again! Hachette Collections Japan have not decided on a release date for these or other models in the series, so for the time being these are all there are available new.  These are showing up on Yahoo auctions at inflated prices already (especially the Celica and NSX) so get yours now at a very reasonable price before they disappear! Stock quantities: NA1 Honda NSX - 1 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1990-na1-honda-nsx 1973 Toyota Celica LB 2000GT - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1973-toyota-celica-lb-2000gt 1968 Mazda Cosmo Sport - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1968-mazda-cosmo-sport 1970 KPGC10 Nissan Skyline 2000GT-R - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1970-kpgc10-nissan-skyline-2000gt-r
