Already covered that- tyre slip against the rollers
I've seen cars with the boot loaded with friends or bags of sand/cement smoking the tyres against the rollers (we're talking mega power here)
Remember, the ramp rate is controlled by the load cells in the dyno (which can generate monstrous amounts of braking force)- the easiest outlet for the power is in the form of slip.
The only accurate way to compare figures is to measure on an engine dyno, if the air temps and relative humidity are consistent between engine tests- and even then it depends on weather both engine test rooms used SAE or DIN standards.
You are missing the point. Like I said before, All external variables like dyno tweaks or "tyre slip" are excluded from the equation. Assumed to be remain constant means no tyre slip.
When someone's car makes 600rwkw on the dyno, you can not simply say "well, that means you car makes 780kw at fly because theres 180kw worth of tyre slip".
  • Replies 61
The thread op has asked How much is 250rwkw in Engine Kw..
That places myself under the impression he's after a comparison of flywheel kw to a rolling road dyno where tyre slip etc does exist.
So tyre slip in my eyes is relevant. As I mentioned earlier.. Clint32. 580hp (432kw) on the engine dyno. On the rollers 338rwkw. 338 * 1.3 = 439kw. Its pretty damn close to what was seen in practice you have to admit. :P
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
