worn out pads, glazed(shiny surface) discs and pads, oil/grease left on rotors after working on car heats up and eventually makes for noisey brakes.
The type of pads used, asbestos while dangerous, was the best friction material ever no clutch shudder no squeaking brakes or warped rotors so sad to see it go.
Cheers matt.
oh yeah dust build up from pads wearing can affect discs but mostly drum brake setups
Edited by mattymagoo22
Cheers matt.
How about I spray water on it? (is it advisable to spray water on the brakes and rotors while washing car?)
or how about degreaser?
Main cause of squealing brakes is the actual brake pad vibrating in the caliper. Pretty common for skyline brake caliper. Happens on my 32 GTR all the time, changed rotors and brake pads and brakes still squeal abit.
best thing I foudn was to get some disc brake quiet (red gooey stuff), take out the brake pads and apply it to the back of the pads, this keeps my brakes quiet for a couple thousand k's, i just reapply everytime i service the car and it keeps the brakes quiet, also its good to go back to a standard pad, the more aggressive ones, ultimates etc tend to squeal heaps more cos its basically metal rubbing metal.
but yeah, go to repco and get some disc brake quiet, costs like 8 bucks.
Man i must try this red gooey stuff.
Coz i got new rotors and pads on the rear (Rda rotors +endless pads) and they squeak like a mother F... lol
I got new stock nissan pads on the front, and they dont squeal at all..
Its so embrassing stoping at a light or slowing down.. Everyone just looks at you!!
Trust me its not just a little squeal..
But i guess you are right Dave32.. more agressive pads do squeal a shit loads.. should have just put standard pads in the rear, but i got these endless pads for free!!
Edited by siddr20
it really isnt hard, take the pads out, squeeze the gooey stuff on the back like toothpaste, then what i do is get the two brake pads and rub the backings of them together, to spread it nice and even on the back of the pads, let it dry a little and chuck the brake pads back in.
when it drys it turns into sorta like a silicon rubbery compound, what this does is absorb the vibrations from the pad in the caliper, dont apply it to ur rotors or the front of the pads as this just gets cleaned off the first time you brake.
i know what you mean by really loud squealing, used to happen to me aswell, just go back to a standard pad, you don't need anything more than that for street driving, if you track your car just keep a dedicated of spares for the track, you don't want aggressive pads for day to day driving, just chews through rotors quicker.
I put the Brake Disc Quiet on my noisy pads and it still hasn't helped. I have RB74's all round and unless I drive the car hard the pads and rotors seem to glaze over but even when the pads are hot they still make some noise. I have decided to go back to standard OEM pads because I also know how embarrassing it is to stop at the lights while screeching and having everybody stare at you. It really detracts from the pleasure of driving the car.
Would changing to slotted rotors solve my problem? I'm inclined to just change the pads but I would prefer to keep the pads if I can make them quiet.
I've had this problem for some time. First, with Endless SSYs and DBA 4000s the squealing was unbearable. We tried everything - chamfering, machining, goo, shims, Bendix Ultimates...
Anyhow, I had Bendix Heavy Duty put in recently and although better, they still squealed.
Eventually, someone worked out that the seals were worn in the calipers, and when the piston moved towards the rotor, the seal tried to roll with it and thus the piston wouldn't detract properly, leaving the pad contacting the rotor lightly = heat = glaze = squeak etc etc
Long story short, I had all my calipers rebuilt. Seal kits were about $100 each caliper and the same for labour. After this, it was dead silent. That was about a week ago and although I do get some minor, minor squeaks, its 1000 times improved. I'm just hoping it doesn't come back.
Just my 2c...
Edited by oblivo
Just my 2c...
Thanks for the info. I will have the calipers checked out. Hopefully a rebuild is not necessary :D
You could be running out of brake pads and it's the metal tab warning you.
Pull the wheel off and have a look at them. Also have a look to see how much gap between the warning tab and the rotor there is.
Most likely, you could be wanting new brakes.
    • Took it for a drive to do some logs, I’m pretty sure my voltage issues and electrical noise issues are gone, I’ve sent a log to Adam and am waiting to hear back with confirmation  att.K23U9eHyiEJxixH6y1__GQfuqK0EgIoDgQFTs9G8x_w.mp4   idle video from that day just because
    • Went looking at mine, reading off the tyre, presumably these are 1st week of 2003. Still hold air (I haven't had to pump them up in over 12 months!)     I couldn't quickly find the date on the front tyres, they were fitted around 2008 to the rims, so probably not quite as old, but they have a lot more dry rot cracks in them. Still hold air.
    • I am now intrigued to go check the dates on the tyres on my Skyline... We need a game of who has the oldest tyre still holding a car up, and successfully holding air (for longer than a 2 weeks I feel is successful air holding).   I feel your tyres may be beating mine
    • Ok, still waiting for a date to get the cams installed on the MX5, why so long, because MX5 Mania has received a few new sets of different cams with different specs for the MZR and are currently trialling them, and working out what is best for 2.5 "powers" with stock internals, in the end if I go bigger than the Kelford stage 1 cams I'll need to look at the valve springs  Hopefully I'll get the news on them next week As for the boot of the car getting fixed, I hopefully pick it up early next week, I was sweating on picking it up yesterday but, meh, it was not to be, so ne weekend cruising for me
    • Ok got some old tyres for you guys...my car has been sitting around un-driven for about 6 years now. I had it on the original rims with the shitty compliance tyres it got it with back in 2006, which were manufactured in 2004... Sidewalls eventually rotted and split open, obviously no air in them and the rims were holding the car up. Just swapped them with some 17" Work rims and tyres which are probably 10+ years old too but at least holding air
