So i solved the idle issue, dont really know if this is a problem but have to ask to be sure..
Had a testdrive and the commander showed small knock readings all the time, 10-13 constantly without any load.
Dropps to zero if the gas is released and break with the engine.
Tried to back the ignition 3 degrees, also tried to add more fuel but the knock doesnt change, could there be something else causing the sensors to go mad?
Did try to put some load to the engine too and got a max reading at 24, but the main concerne is the constant knock..
/Fredrik
As long as the knock doesnt go about 20-25, dont worry about it.
10-13 is normal dude. There is always going to be some noise.
Thats just part and parcel of the motor innards moving around, a motor isnt 100% silent and thats the 10-20 knock that the sensor is picking up, just engine noise
Thanks, then i dont have to get worried until i can get the car properly tuned..
Never heard about the constant knock readings before..
Better be safe than sorry :)
Edited by Fredde
what sort of conditions did you recieve the high knock at for 79? thats the question also u need to ask.. but yeah i see about 8 - 10 normally, and mine ive noticed mainly drivetrain related or going over bumps does it too damn knock sensor
i have a 32 gtr which knocks to 30 under minimal loads such as cruising and at no throttle when eng braking. Under wide open throttle it doesnt go over 30 but if i add timing the car will ping quite noticably for a split second but the knock level doesnt go over 30. My conclusion is a dodgy knock sensor. Ive had 3 power fcs in 3 previous cars and never have seen this before. Oh and the eng is quiet at all times except ticking injectors. That might help
Thanx michael..
you might need to use the map tracer and freeze the tracer when your knock waring light comes on. Then you need to go into settings and reduce the timing in the area you froze the tracer. Start by taking out 1 degree at a time. Im sure if you did a search in the FAQ section there would be a step by step instuction of how to do it.
Thanx Michael....
yes it may.
hmmm i get high knock noises sometimes... i took it into boostworks and they tuned it and said there was nothing wrong wid it etc. but since then i still get high knock readings every now and then. so i just presume thats the way the car is.. and its been going on bout 5 months now i guess
I deffinately wouldnt be happy with 10 - 15 knock without load. The engine doesnt make that much noise. When im cruising my knock sits on 1-2 and ever now and then will tap 3-4 and go straight back to 1. In other words its a long way off 10 - 13 constant.
They probably said it was ok because it was ok on the dyno. They cant match exact load on the rollers as your car will have on the street. Especially if you use a bleed valve and you are already doing 4500 rpm plus (which is when most peoples turbo is making boost) and you floor it the boost will spike higher than what the vehicle was tuned at. Some tuners dont allow for this when they are tuning but in their defence some turbos and boost controllers dont work that well either.
You can correct it each time you drive by going in to settings scoll down to ign/inj press next, there will be a 0 highlighted next to the 0 says adj i think, arrow down twice and it should say -2 then press back until your on your monitor screen. This will take out 2 degrees of timing through the whole map. Once you turn the car off the ecu will go back to normal settings so this will need to be done every time you start the car. This will work until you have the timing removed from the area that is the problem.
Thanx Michael...
The only way to really tell is to use either a knock meter like snap on or some of the Jap ones like TOMEI. Each engine is going to register different knock readings dependent on numerous factors EG: Forged piston or standard, bearing clearances etc.
I had one car that had twin screamers and one was slightly touching the engine and would register obscene readings.
I have also heard that some of the older fc's had some issues with knock readings so if unsure get it double checked as $100 of labor is well worth it compared to a engine rebuild
    • I'm not aware of e30 in Australia, but I'm pretty sure e85 is still around. You really want a setup with an ethanol sensor so you can run any mix of ethanol depending on what you can access. Fuel Check NSW app shows 14 site in sydney metro with e85. What are you adding, will you put in bigger turbs too? Apparently the wastegates are pretty small and can't bypass enough as you run more boost.  I'm sticking to 1.3 bar with 98 on the standard turbos with my tune on advice from the tuner, and boost drops significantly in the top end; apparently larger turbos with larger wastegates are needed to get anywhere meaningful from there.
    • Amazing work Duncan! It is never easy to pick up someone elses project and work all the parts out that are missing
    • Hey Ppl,   I am about to tuned my Infiniti Q60 with E-85 and if you can tell me some location where I can top up my car that would be great.   But my other question, is E-30 available because this tuned requires less mods parts and any info you can offer would be greatly appreciated too!!
    • Hey Duncan,   The parts have already been made by AMS Performance in Chicago, but I still to confirm if there are in Petrol Station in Sydney that sell E-30.   I know there are a few seeling E-85.
    • That probably needs a specific thread....and if you want to run different ethanol mixes you will need the ethanol sensor and wire it into the ECU (which has different requirements depending on the ECU year apparently)
