I have an atmo venting BOV so i dont the need the pump back pipe
So i removed it.
I have done the folling please tell me if this is right or wrong.
1. removed black pump back pipe
2. bloked of holes the pump back pipe left in the rubber intake pipe between AFM and turbo
3. Put a Breather filter on the breather pipe as seen in the photo below.
Is there any thing else i need to so
cheers
yeah that will work for you, probably a better idea to run a oil/air seperator (catch can) but there isnt anything damaging about that setup as long as there is no chance the plugs you put in the intake pipe will fall into the turbo.
i pretty much did the same dood, but i just cut off the bov return n left the blow-by hose connected upto intake.. when i can be bothered il get a catch can, im in the process of running plumb-back again so everythings gonna get re-done properly so for now its kinda just to get me by
also cant you get defected for havin a breather?? emissions crapola
Edited by 2gceffy
So i removed it.
cheers
I love that purple. I painted my coil cover with that. Supercheap export purple :teehee:
When I installed the last atmo bov, all I did was bung the return pipe, that's it.
yea all i have had for the last year was a bung in the return pipe now i want to get rid of the pipe to tidy up the engine bay.
I got the paint from repco its a really good colour and is almost the same as the HKS Purple i have also painted my strup brace hands the same colour.
So i removed it.
cheers
1. Easy if you took off the cross-pipe to paint the covers, same thing you just undo another additional bolt take off a couple clamps.
2. Just stick some sort of plug in there with a clamp around it, alternative weld up a metal plug with a lip to stop it going into the intake.
3. If you still have have the black hose that returns to the to the intake you can just put a monza oil breather on it.
    • Certainly. It is probably broken under the wire style clamp. At least that one is easier to get at than the front one.   Sounds like it isn't a major leak, I'd start with backing off the the water feed and return banjos into the turbos half a turn then tightening properly. Hardlines can still crack over time, either in the tube (particularly when turbos are changed if the banjo is siezed in the the tube) or at the brazed joins between the lines and the banjo fittings. A coolant system pressure test will reveal all. BTW you'd be able to get a sump without exchange, it will just cost more as they will have to source another stock one for the next customer. If you want to address the sump a much better option is something like this https://www.hioctanedirect.com/hi-octane-racing-sump-extension-nissan-rb26 that you weld in locally (and add the oil return fittings at the same time)
    • Pretty sure you are thinking of the throwout bearing there (which you should change when you change your clutch), when they are worn they will get quieter if you put your foot on the clutch. An input shaft bearing is turning/noisy at all times.
    • I’ll have more of a look into Recaros over the weekend. It’s taken me 2 days to figure out which Bride seats suit my application haha.
    • I am aware of their presence, but the product page looked like that conversion will eliminate the AWD capability. Fact remains it's kind of a hassle to send my oil sump halfway around the world and buying an extra one is expensive and unnecessary. Before I go hat route I'd explore more local options.    Would you recommend I just pull the engine and renew as many things as possible since I'm already having problems with some leaks? Would have to get an engine crane first though.
    • Are there any indicators that the vehicle is in limp mode?  Any dash light, or something.  Or is it just lack of acceleration?
