There's 4 very good write ups with pictures on this site. Everything is in them.
Take your time and take mental pictures or physical ones of everything you haven't seen before or are unsure of as it will help when putting it back together.
have the correct tools handy. Get a balancer puller that uses the two m6 holes to pull it off.
Melbourne, Northcote area. I have had a look at the step buy step procedure, I guess i am just not 100% in lining up the timing belt marks.
You'll be fine :) it's so simple. Wind it over and watch the cam marks and that they align, then check the crank. Done.
Question, once I have aligned the the marks for inlet,exhaust and crank, i then remove the tensioner, once the tensioner is removed / released ,will the belt want to move the cams from the original set location because of the tension lost ? if so how is this avoided or rectified?
one other question, just to clarify, the harmonic balancer retaining bolt is L/H thread or R/H?
Balancer bolt is normal thread. Righty tighty lefty loosey. There are a few ways to undo it.
Cams won't move, they're locked.
I'd advise looking at all Diys we have on this website and getting a good idea on how to do it.
Maybe someone here who is close to you can come and help too
People tend to stuff up the tension, usually too much.
Definitely do camshaft seals, and crank seal.
Yep I did, I guess?.
The gates belt is a LOT stiffer than the genuine and dayco belt, so at the same tension of the original, the gates felt a little loose. I did it up a bit tighter and it whirres
Just a quick question fellas,
I changed the timing belt on my r33 s2 det last night, all went reasonably well.. This morning i took if for a drive and every thing seemed fine until I entered the freeway and opened it up a bit, as load and pressure built up above 4.5-5 rpm + It seemed to bet a significant loss of power, now I would also like to mention that I have upgraded the turbo due to the turbo spitting it self the other day, the up grade was from standard - to a Garrett T3/T4 Hybrid A/C CHRA Conversion. (Car not tuned yet)?
is it a possibility the crank angle sensor could be 1-2 mm off even though i make it? or is it just running very rich etc..
I know this is not the right topic , a link to the correct topic would help or some insight would be appreciated.
Edited by Antek
I don't know much about that turbo. But have been in a few skylines with upgraded highflows and bigger turbos without tunes and they are slow and shouldn't be driven hard until you get a tune.
Did you mark the cas before taking it off?
Should check your timing with a light anyway because no mark will get it back to spot on. A small movement on the CAS is big in degrees, you could be up to 10' out? And that makes a huge difference as well, even 5 is easily noticeable.
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
