I'd get a nismo, cause I did.
The nismo pump actually fits BETTER than the factory pump, and comes with its own bracket etc. I'd also order it from greenline because its $320 from there, and Nengun stuffed me around, taking 6-8 weeks to get it to me.
f**k that. Thats too long of a wait.
  • Replies 78
Where did you get your Tomei for $340 inc delivery? Nengun is $370 at the moment.
From all the threads ive read, Nismo and Tomei are on par with each other. Can anyone name a reason why one is more preferable than the other?
Sorry mate,
Just re-read this thread and noticed you asked ages ago and i didn't reply.
But as already stated, i got it from greenline too. Delivered in about 1 week !!!! Awesome!
They were close to $50 cheaper delivered than nengun....the $340 was including delivery.
.... and the Tomei also comes with the full bracket etc...
Go to the DIY section and someone had the "easiest fuel pump upgrade ever" thread or something liek that.
It's not mine but i posted heaps of pics in there of mine so check it out.
But if you can get a Nismo for $320 delivered.get that !
Damn that's getting really cheap.
Also :
(From Nengun)
http://www.nengun.com/nismo/fuel-pump-skyline
Nismo is 4.6L/min
http://www.nengun.com/tomei/fuel-pump-nissan-skyline-r33-gtr
Tomei is 276 L/hour
4.6 x 60mins = 276 L so they are the same rating when comparing the GTR items
They are currently $370ish delivered from nengun and when i ordered mine they where about $400 so it's come down nearly $30 with the dollar increase.
Greenline might have em for about $310 delivered now !! Cool !
Flick em an email and see what they say.
and let us now the price son!
Good luck :w00t:
http://www.greenline.jp/
Nengun hae the fancy website with less than fancy service but you do get your stuff.
Greenline's site is still good, just not as fancy.
They have the same stuff and i think it's only email based, well from my experience it is.
They reply either same day or next with a quote breaking down the cost of item/deilvery.
Deposit money into their account, they'll confirm it.
Both sites are good in my opinion. (if prepared to wait)
I check prices on both for any item i wanna get and go with the cheapest,
And it always depends on the item on who is cheaper,
Fuel Pumps - definately Greenline by about $40-$50
EBC - about the same from memory but i got mine from Nengun
Z32 AFM - Nengun was cheaper by about $50 so got it thru them, took about 6 weeks though
PerfectRun has the Nismo Fuel Pump for R33 gts25t for around $330-340 delivered.
http://www.perfectrun.com.au/performance%2...smofuelpump.htm
i've ordered heaps of things from these guys like
-guages
-spitfire coil packs
-oil cooler kit
and usually it arrives around 2 weeks at my door step.
AFM was thru nengun and as advertised on their site.
For some reason it's thru the Tomie AFM Z32 and you recieve a Genuine Nissan one.
It was $349 i think delivered which is about $40 more than what you can get in Aus thru the traders...but...I've been burnt on 1 dodge AFM and I'm not wasting another $300 on another...plus the money wasted on a tune which you can't get back.
So the extra cash was a fair trade off IMO
I am getting the impression there is NIL difference between the Nismo and the Tomei, except for the name!
And they both have very reputable names so i'd just go the cheapest..which i did.
Also, i've seen pics of both on the net and they look identaical although that's not confirmed.
Bracket and assembly and pump all look the same.
..and the pump is completely surrounded in black plastic so you can't see any part numbers even if you wanted to
Either way, they are both gunna be fantastic, pic whatever takes your fancy and you'll be sweet as pie.
Like warm apple pie .. haha
Are these Tomei/Nismo pumps good for 400rwkw?
Two choices between in the tomei/nismo fuel varients, one is 248lph the other is 276lph
Is that good enough for 400 rwkws? only benefit is the fact is direct bolt in replacement no ffffing around to fit :thumbsup:
Cheers
A
    • 2 does "sort of" applies, maybe......but looking at what parts would be needed for the swap to get engineered, registered, and insured, and basically that's everything under the car, the modifications the make it legal would be problematic and horrendously expensive, all for a street car that just cruises around and hits a few twisty roads on the weekends Also, from looking at the NSW rules and Regs, with all modifications that is required just to make the car safe and not twist itself to pieces, and then actually get registered for street use, may still be impossible nowadays As for 1, when you add in a fresh engine, fresh transmission, rear cradle and diff, tailshaft, suspension, brakes, cooling, and all the other fabrication required, your probably looking at up to $100k to do it right, all for a 20 year old MX5 that is over engineered and you would never be able to actually use the power it has on the street, much like your beastie, which I love, but you actually track that thing and can use all of its powers in anger, in a safe environment  Hell, the old Bogan Cruise Ship had more power than I could use on the street, and in hindsight, I went a bit silly on that thing, it didn't really need the 500hp it had for what I actually used the car for, it was fun, but basically unusable on the street if you value your licence  As for cams, yeah, I'll probably book it in for them to get installed and tuned soonish, like next month after MX5 Mania are back at work....... and yes, I've already sent a email to bin the turbo quote and quote instead to install cams and a new Fluidampr balancer that will suit the 2.5 better than the OEM 2.0 balancer that is swapped over for the 2.5 install, as the balancer needs to get pulled to time the cams it's a while your in there sort of thing I did think a bit about flex fuel for a laugh, but being na, and no where really around locally anymore to get E85, I've binned that idea, so no sweet sweet corn smells are set for the car I wish E85 was more of a standard fuel, it's better for the environment, better for tuning, plus that sweet sweet smell we all love As for fitting in the family, that's not needed, as everyone in the family already owns a car that can seat 5 humans comfortably enough, the MX5 is "my toy" As for buying a car that is already built, nah, I would rather pick and choose my parts, I enjoy the process, and in the big picture, the additional cost is well worth the enjoyment, and the occasional frustration, I get out of doing it, albeit with other people spinning the spanners, and me, just paying the invoice 🤣
    • Excuse me, but 2) does apply 1) Would also apply if you consider how much is spent in the alternatives. Also there's the option of 3), buy one pre-built that you can put your family in (it's me, it's my car)   That said, I went on a ~500km drive the other day. I didn't use anything more adventurous than 3rd/4th gear at about ~3000RPM and 50% throttle and I was going as fast as anyone has any sense doing on a public road, with enough grip to the point where I didn't want to go any faster. I was obviously under the limit of the current car etc etc. MX5 with 2.5 N/A to achieve the same speed would be more fun for any road scenario. Maybe consider cams. I wouldn't boost it. The use case is just not there and it won't actually make the car more enjoyable unless you really do plan on wringing gears from 1st to 3rd (at least) at 100% WOT on a public road to 150+kmh.
    • Great if: 1. You had all of the money for everything else that is required  2. Lived in a country where you could actually do this and drive it legally on the road Sadly, neither applies to me As for the turbo, I am having second thoughts, mainly for engineering/registration legality reasons and insurance  Not saying I've finished doing stupid things that I probably should do to the MX5, but boost, and V8 engine swaps isn't on the cards Strange, but true
    • I like this page, better than that silly turbo kit   https://v8roadsters.com/product-category/engine-conversions/engine-conversion-lsx/engine-conversion-lsx-nc/
    • That would be my Shoei helmet
