yeah I would say just an ECU. The nos kit will come with fuel jets too, so you will just need to fine tune the ign timing and fuel mix a little with the ecu when the nos is active.
man your in some trouble.
The greddy kit is a NOS brand kit with a greddy controler, you buy that and you are paying way to much !!
Much better of buying a local kit. I would look into Zex if that kit was in your budget.
Also that kit I believe is a dry kit. Your really better of with a wet kit for turbo cars(argueable i know)
If you are running a wet kit all you would really need is a good fuel pump and a turbo with a steel wheel.
You won't need ecu/tune or extra injectors with a wet kit.
Or you can burn of your turbo wheel and use it as an excuse to upgrade, waste of $450 turbo though.
Your engine will handle 50hp shot of nos all day every day, just jet the wet kit on the rich side.
Usual nos things also apply. Change heat range in plugs and take about 2 deg of base timing out.
Tuning the NOS on the dyno would be the ideal though.
You DON'T need an aftermarket ECU to support that level of Nitrous Oxide use in your car.
You DON'T need a tune to support that level of Nitrous Oxide use in your car.
You DON'T need a steel wheel on your turbo to support that level of Nitrous Oxide use in your car.
You DON'T need larger injectors if you buy a 'wet' kit to support that level of Nitrous Oxide use in your car.
You DON'T need to adjust your timing to support that level of Nitrous Oxide use in your car.
You DON'T need a fancy progressive controller in your car to support that level of Nitrous Oxide use in your car.
You DO need '7' heat range spark plugs to support that level of Nitrous Oxide use in your car. (BCPR7ES @ 0.8mm)
You DO need a reliable fuel pump to support that level of Nitrous Oxide use in your car.
You DO need someone with half a brain to fit it and work out a tune (with the jets) to support that level of Nitrous Oxide use in your car.
You DO need to bear in mind that you shouldn't be activating it under about 3000rpm to support that level of Nitrous Oxide use in your car.
Adrian
I think you will find that this is very simular to those that say 15psi + on an rb25 turbo = wheel off
It works for some people and not for others, its just a rule of thumb.
At any rate I don't think you could argue it will increase the chances of the wheel coming off and people should be warned.
I am sure you have some story of how you did it and it was fine for you ... IN YOUR CASE.
The same applies for the timing, all thnigs being equal you are probably right. Bad or low octane fuel will make you wrong.
Edited by Butters
Dude, I wouldn't be arguing about nitrous with 2rismo...
He knows his shit.
Edited by BAMR33
He knows his shit.
Stumbled accross an un-questionable net god have I ?
If he know's "his shit" he will know not everyone is always right about things(including myself :blink: ) they believe to be true and accept other peoples opinions for what they are .....
Edited by Butters
Just remember who said you shouldn't argue with me....it wasn't me and I don't think an argument is necessary. Just so we're clear. I very much appreciate your very last statement. :D
It's very different to that scenario, in fact. Running a stock RB25 turbo at 15psi is dramatically different to running the small amount of Nitrous as described in the first post. This is from experience and measurable EGT's etc not from guessing.
For a number of reasons it can actually decrease the likelihood of exhaust wheel de-lamination.
What I've said above is based on experience on more than just my car but certainly mostly on my car. However, these suggestions are very different to a sensible rule like the suggestion that you probably shouldn't run 15psi+ on a stock ceramic wheeled turbo for long periods (which I absolutely agree with). They are based on results and facts as well as undeniable measurements taken over a few years by myself and on the vast experience of those with many years more nitrous experience than myself.
The same can be said of any modification so I hardly think that's a fair statement. Even if you did re-tune a car for nitrous, you wouldn't tune it with 10:1 AFR's - you'd stick it where it made the most power and safely. Just like too much ignition timing, boost, compression etc, low octane fuel makes for problems.
One more thing on the ignition issue - if you'd genuinely like to understand why adjusting the timing for such low levels of nitrous oxide isn't necessary, please PM me and I'll explain it. Same as anything, when you understand a couple of key points it becomes really simple. It would surprise some to know that you can actually start putting extra timing in when using a moderate amount of gas! :D
Yep, sorry dude. Wasn't having a go at you.
Its a pet annoyance of mine when people get idiolised(with or without good reason) and you are not allowed to have a different opinion.
I am interested in this comment, if you wish to explain it further ?
I agree with everything else you say. Be quite intersted in your EGT results too if you wish to share ?
Buy the NOS kit from ROCKET it will be far cheaper.
I ran 100-150hp wet nos kit on my V8 soarer with only a decent fuel pump. We also set up quite a few NA 300zx with 100-150hp NOS kits and all are still going strong 6 years later, reliability is all in the setup and restraint on behalf of the owner....... it is too easy to keep fitting bigeer and bigger jets until something goes wrong.
Be sensible and you will have no issues. The ceramic wheel on the turbo may be an issue if you go too big in the jet size but for 60-80hp you should be sweet.
hay nothing wrong with running 15 psi on a stock turbo, for some reason i can't kill mine, been doing it for a year now, and the bustard still wont die. Actually its 15.6 psi. HIHIH.
hahha soon it will happen lol. I ran 17psi on my ceramic turbo, lasted 12months then one day i took off from a set of lights and then i heard a ching ching ching sound, and then no more boost more me hahha. Its fun taking out our cat to remove all the peices of the ceramic turbine... :laughing-smiley-014:
As 2rismo has already said, setup wise there isn't too much in the way of hardware required.
The tune is important however. Getting the mixtures right with the fuel and nitrous jets isn't really hard it's a little time consuming. 2rismo, may have a few combo's to try if you start with similar components. The timing needs a little backing off and you need to be prepared to drive the car a little differently. If you can get the solenoids as close to the jets in the intake as you can, so you don't have any 'run on' and you get a better hit if you haven't invested in a purge kit (still no where near as good though).
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
