Hey Guys,
i've just completed a few mods to what was previously my stock R25DET R33
Here's a list of mods:
3inch Exhaust, front pipe back, including high flow cat
HKS pod
Greddy FMIC
HKS Electronic Boost Controller
Now there have been a couple of issues that have come up as a result.
The car was previously runinng perfectly, but now that i have installed these mods, it seems to be hunting a fair bit on start.
After driving it for a few minutes, it usually works fine.
The other things that scared the crap out of me the other night is when i had boost up around 14psi and the turbo just suddenly cut out around 4,500-5,000rpm
What can i do to resolve these issues??
Thanks guys
Edited by Tommmo
https://www.sau.com.au/forums/topic/169504-r33-gts-t-got-a-couple-of-issues/
Check all your vacuum lines to start off with that can cause some problems. As for the turbo cutting out it could be fuel cut. Dont know too much about nissans but i know with some turbo subarus once it his boost cut it will bring a limiter it. Do you have anything like a fuel cut defender?
It would probablly be with runnnig a fault check on your ecu to see what fault codes it throws up.
Hey I reckon you check your TPS (throttle position switch) this can be affected. 14 psi is too much on a stock turbo turn the boost down to 10psi to be safe. Your pod filter would probs be causing probs too cause its sucking in hot air. Id suggest get some kind of aftermarket ecu or atleast fuel controller piggyback. If you search you'd see this is covered tonnes of times. good luck mate hope it all works out hate hearing of a unhealthy R33. also go to a mechanic and get a consult plugged into your car and when your car starts to hunt they'll tell ya exactly whats up.
Edited by LatinR33
I run it at 10psi all the time, i only have it at 14psi occasionally as i've heard they can handle this much. (i hope)
Engine wasn't designed (or programmed) to ingest air at 14psi. Hold it back (maybe 12psi), and it should be ok.
If you are running stock ECU, try a reset to have the ECU re-learn the startup.
Check all hoses as could be a leak somewhere since the tubing might be old and flakey..
You can try cleaning you AAC and resetting the idle -> http://www.skylinesaustralia.com/forums/in...howtopic=110431
Also sounds like R&R'ing at high rpm/ high boost. Since night = more oxygen in air and car R&R'ing (Rich and Retarding)
    • Hey all, not sure how active SAU is anymore but will ask away anyways. Just wanted to get some experience on the 2008 model GTR CBA model.  I've hit that age in my life (43) where I'm like fk it time to get my dream (midlife crisis) car. Looking at importing one in and seeing if these can be reliable if the main flaws are fixed up. Plan is to keep money aside to do the following straight off the bat to future proof it: * install a stage 1 rebuilt trans with all new bits and pieces.  * install a new Bellhousing from the later model GTRs. Or potentially an upgraded stronger version like MAD or ATR. Besides the above two things and typical maintenance items anything else you'd recommend doing.   Been speaking to a few people and the engine on these are very reliable apparently. But keen on the view of the community here. Hoping to find a nice grade 4.5 with low mileage in Grey. I'd go black but swirls too easy. Look forward to your responses and feedback. Cheers
    • Do Alan and Keith work on Skylines now? I remember buying stuff from them when I owned my Ralliart Lancer a few moons ago. Definitely genuine guys and be excellent if they dealt with the skyline platform as well.
    • Hey all, I'm Gaston from Sydney's West.  I was a member on here when I was a younger lad and owned a mint R33 GTS-T. Ended up selling it and getting married having kids (yadda yadda) we all know how the story goes. Now I'm back with the intention to get my midlife crisis (dream) car ... a R35 GTR.  You'll see me about asking questions and searching the forums. Good to be back and can't wait to get back an Import again.
    • I have to put something here in order to post the photos. From what I could gather there's more enthusiasm for modified cars now than there has been for years. There were probably more younger people there than older (me included lol) which was a good sign.  It did seem like the record least amount of representation of the 90's era hero cars on display though. Like maybe one or two examples of S-chassis Nissans, and maybe 3 or 4 R-chassis. By comparison there were a lot of Civics from that era but in all there were about 10 - 12 EG/EK Civic Type R.  Euro exotics are always there in large numbers, led by Liberty Walk...... say what you will about kids using markers to scribble on a Ferrari F40, it did seem like a stunt to infuriate Ferrari enthusiasts, or Ferrari itself. I wonder if there's something more to it. Either way LBWK have done some heinous things to a Lamborghini Miura this time. They should stop now.
    • Engines and drivelines are not war stoppers for me mate, busted arse bodies and un-obtainium parts and panels are though Both cheap Brumbies I looked at had trashed tubs and a fair bit of rust
