Picked up my self a 1990 r32 gtst a week ago and have been having a play.
Modified the dash a bit. Moved the aircon controls to the bottom. In the 2din space above plan to install either a new head unit and foldout vga touchscreen or flush mount a vga touchscreen in the space and a new head unit where the ash tray is.
After that is done will be installing a simple PC and hooking it up to the ECU with some voltage sensors.
Will then be able to setup digital gauges and data logging.
Will be writing the software my self and will probably include a media playing in it.
Anyone wanting to do something similar?
Will have some software done soon if u wanna have a go aswell.
Will be great for road tuning due to the data logging
https://www.sau.com.au/forums/topic/169519-dash-modification/
Nah no effort at all.
Dash modification will be easy have done a few before. Moving the aircon control was easy will look better with the LCD up higher.
Have decided to go the built in LCD panel as it looks alot classier than the pop out screen.
I have been programming since I was 8 so the engine monitoring software will be pritty simple.
Engine sensors are easy to read thanks to a simple USB device that reads voltage levels. Will need to connect a map sensor to read boost in.
Simple as. Hopefully be installing the monitor this weekend. And will put the carput together aswell.
Then will have to wait for my USB device to arrive then the fun starts :)
nice work dude, i did something similar with my ebc
going to chop out the ash-tray and lighter soon, and add 2 gauges there
^^Thats da bomb..... Anyone else got ideas how they hold the Power FC Commander unit? Im currently using a mobile phone holder, hooks onto the air cond vent on drivers right side but am not very happy with it. It doesn't hook onto the vent properly. Cars a 34 Gt-t btw.
Velcro dude
you can use a rsm/ safc stand... the legs that stick on the dash can bend so you can bend them into position with double sided tape... then use velcro to stick the power fc controller on the stand with velcro
but that lcd screen looks unreal! very very nice work!
also with this pc in the car, i know theres a thread in NS about it
I have been toying with the idea of a car pc for a while now, how were you planning on powering it?
The way I see it is I wanted to use pc parts I have at home, I could use a standard 240V PSU and install an inverter/transformer to go from 12V DC to 240V AC. I don't like the idea of having 240V AC anywhere in my car.. The other option is a 12V DC PSU can be bought for a much heftier price..
I would also like to know what sort of LCD screen you end up going with..
Cheers,
Bubbs :P
The screen to the part of the dash where the dials sit? or the screen to the clear plastic cover over the dials? For my application I was just going to mount a screen to the left of the centre console and a neat arm dohicky that will fold down and out of the way..
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
