I've always thought the R34 needed more guts down low, so I thought this would be the perfect conversion apart from a V8.
I'm curious as to whether a VQ35DE with a turbo would go into a R34 without many hassles? Like would the mounts meet up? Would this cause balance issues? As an estimate what sort of money are we talking here?
The Nissan team in JGTC has done this years ago when they were making a prototype engine for the new GTR.
Im pretty sure Top Secret has also built a R34 GTR with VQ35DE Twin Turbo, might have been stroked to 3.6l or 3.7l even.
I believe Nissan used VQ engines for the last year that the R34 competed in the JGTC, not sure tho.
Also, i think the VQ3.5 is lighter than RB engines.
Go a twin-turbo set-up from APS, would be an amazing car. Always wanted to do it as well, but would miss the sound of the RB.
i think modify your r34 engine.. there is almost no limits what you can do to rb25det to make it faster..
As for guts RB25 or RB26 can provide you with all the power you could ever desire...
Yeah, except he said in his first post that he wants more grunt down low. What can you do to an RB25 to make up for that 1L defecit low in the rev range, aside from nitrous or going to 3L (the latter still not being enough to compare torque to a VQ35DE with a turbo)?
I've driven VQ35DEs with centrifugal superchargers, single turbos and twin turbos. Off boost those things feel like a standard VQ35DE (i.e. lots of torque), and on small amounts of boost they make an impressive amount of power. The bottom end will take just under 300rwkW which will retain all that response while giving you a usable amount of power if you get on the boot.
If you can afford to do it, do it. The engine is lighter and more compact, although trying to get the mounts and the gearbox etc to line up might take some work.
Yeah that's the only downside. Trying to get everything to mate up easily. I'm guessing this would be a very expensive job! Even the VQ35 without the turbo in a R34 would be awesome. I really miss the low down torque!
How much power do you want? Are you chasing power, or do you just want lots of bottom end and midrange to make the car as "lazy" as possible to drive (like an old Commodore / Falcon with their cast iron V8s)?
If you just want something that you can whack into a higher gear and cruise around in, with maybe low boost down the track, give some thought to the VQ40DE out of a current Pathfinder. A lot more torque (its a stroked version of the VQ35DE), but is down in outright power and has a lower redline. It also runs a slightly lower compression, so if you do go for low boost you can run a little more with this engine safely.
Only issue is that the engine is a bit taller than the VQ35, so you may need a power bulge in the bonnet. Engine's also a transverse mount, but the 350Z drivetrain apparently bolts straight up to it.
i reckon just mod ur 34 turbo instead u can prob make it have as much power n torque as a V8
yeah u could whack in a V35de but the amoun tit'll cost u is gonna be thru the roof
n not to mention one yellow from ur local popo n u can kiss those mods gdbye =)ma 2 cents
If you're not concerned about fuel economy, another suggestion would be to run the final drive / LSD out of a NA Skyline. That'll pull your gearing down, and so you're more likely to stay up in the rev range where you can more easily make boost.
No idea how much a VQ35DE will cost you here. A brand new engine from Nissan Australia is upwards of $8K, and there aren't enough written off 350Zs yet to have much of a front cut market. Jap importers might be able to bring you something in, though.
Pro Concept told me they have a spare short motor, which I don't think they need since they're no longer working on a race car. Not sure what bits are missing though.
    • And if you want more power, more reliably, and cheaper, go get the Aussie RB... The 4L Barra and put that in instead.
    • No cats will keep discolouring the rear bar. Sends white paint a weird yellow stain. Cut and polish normally gets it out, but you'll be doing that every fortnight I found.
    • Both heads will be equally reliable or unreliable depending on what you do to them.  Stock the RB26 head will flow more. You have access to the stock intake ITB manifold on the RB26 cheaply which flows really well(1000hp+).   Arguably more aftermarket support for RB26, though in Aus we love our RB30 SOHC heads too.    The only downsides to the RB26 head is if you have a VL commodore and want to keep the SOHC look.  Where you may have an issue is drilling out the rb30 block for the bigger head studs but if you are building a big power motor you'd probably put bigger studs on the SOHC head too.  This is just about finding a good machine shop, sometimes easier said than done.  RB30 head worked can make big power just like a Rb26 head, so really it actually more comes down to what your preference is for your car.  People now even making billet versions of both.
    • 2630s work perfectly well. There is something to be said for just using the 30 head, as it saves all the pain of the conversion, still makes tons of power, still sounds cool, etc etc. 2630 will obviously make more power again, but the differences are not stupidly big. It really depends on whether you're racing for sheep stations or not. If it's dead serious, then it's a 26 head. If it's just for fun, it could go either way. But the 26 head and the effort to get it set up, etc etc, is part of the fun.
    • I've been building a 26/30 for a few years now. I've had the head built with all the good stuff. I had a 32 gtr but blew it up and yes its all going into a vl but im looking for some advice from some RB nuts on pros and cons on putting a 26 head on a 30 bottom end is it worth it Works are as follows Head -Extensive porting 1mm oversized supertech valves Supertech double springs Supertech valve guides Supertech titanium retainers Tomei solid lifters Tomei 270 x 10.25 cams Head drain Bottom end series 2 rb30 block Cp ceramic coated pistons Eagle rods Romac balancer Oil restrictions  O ringed blah blah spent a fortune And will get a girdle because the 30s arent used to handling that much rpm Nitto billet oil pump Hypertune plenum 6boost mani Refurbed astra pump thats the cover for it in the boot I did have a precision 6262 but sold it because drag car life. Currently building the ass end full 4 link floater rear end with a 2 speed  But the dilemma i have is my mate rekens I should just stick with the 30 head for reliability. Has any one had any issues with mounting the 26 head ie compression blowing gaskets etc. Just looking for some advice from people who have gone down this route. Here's some photos. Blew the oil pump in the gtr and decided to rip the motor out at the time and do a full build only to find it had been a repairable write off so went down this path.
