Hey guys!
Currently setting up my new project.
Im on the hunt for 500kw on the rears.
Interested in knowing the following
- cams? 256?264?272?
- Turbo? 3540? T04z? Gt42?
- How Much boost?
- Injector Size? 750?850?1000cc?
Is there anyone on the forum that has 400/ 500 kw setup in their car.
Curious to know how much work is required plus the components needed.
https://www.sau.com.au/forums/topic/169568-500-kw-rb-26/
R32 GTR
Apexi PFC D-Jetro
Garrett t04Z turbo running 24psi
Apexi 53mm External Gate
Sard 700cc injectors
HKS Fuel Rail
HKS Fuel Reg
HKS Step II cams 272 272 10.2mm lift ,
HKS Valve Springs ,
HKS Valve Guides.
HKS adjustable cam wheels
Jun Oil Pump
Arias pistons with n1 rings
Pauter Conrods
608rwhp or 454 rwkw's at 24psi on Ultimate 98
https://www.sau.com.au/forums/topic/169568-500-kw-rb-26/#findComment-3133635
As per the graph, max power is 578 hp at the rear wheels. This is an improvement of 37 hp on the same dyno by fitting a 272IN cam (previous 264) and spending dyno time optimising cam timing.
Setup is:
N1 block
HKS 2.8L crank
Nismo bearings
Pauter rods
ATI crank damper
HKS nickel coated pistons
GT-RS low mounts at 25 psi
HKS bridged manifold
HKS hard piping induction kit
Apexi 136mm IC
Greddy plenum
HKS fuel rail (twin entry, single return)
HKS fuel regulator
HKS 680 injectors
Nismo intank fuel pump (direct power feed)
HKS step 2 cams (272IN, 272EX)
HKS guides, springs and retainers
HKS timing belt
HKS cam gears
HKS metal head gasket
Ported head
Trust oil pump
N1 water pump
HKS dumps, pipes and exhaust
PFC D-Jetro
Blitz dual solenoid BC
Splitfire coils
HKS Twin Power CDI
HKS twin plate clutch
GTS4 diff centres front and rear (shorter ratio than GT-R)
https://www.sau.com.au/forums/topic/169568-500-kw-rb-26/#findComment-3133643
just picked up my new GTR
1992 GTR
1000cc injectors
3X bosch fuel pumps
Standard plenum
re-ground standard cams
ARP rods
unknown pistons
T51R SPL BB turbo
AP racing Triple place clutch
Autronic computer X2
re built standard gearbox
AFR btween 12 and 13
last dyno:
631.3 ft/lb torque
578 kw at all 4
775.2 hp at all 4
that was running 2bar
dyno sheets to follow when i get scanner working
https://www.sau.com.au/forums/topic/169568-500-kw-rb-26/#findComment-3133647
Setup is:
N1 block
HKS 2.8L crank
Nismo bearings
Pauter rods
ATI crank damper
Apexi 136mm IC
Greddy plenum
HKS fuel regulator
HKS 680 injectors
HKS timing belt
HKS cam gears
Ported head
Trust oil pump
N1 water pump
PFC D-Jetro
Splitfire coils
HKS Twin Power CDI
I just made that same power with GT-RS turbo's on 21 psi with pump fuel and a light tune.
a few differences though Nissan crank, bigger cams, more headwork. but much the same. All big $$ brand name stuff, Jun Hypertune etc. It will see some more boost this week as well as some race fuel and increased timing figures.
but budget at least $25000-$30000
https://www.sau.com.au/forums/topic/169568-500-kw-rb-26/#findComment-3133679
1990 R32 GTR
Split fire coils
HKS 264/8.9 cams
OS Giken cam gears (not tuned)
Sard 850cc inj
Bosch 044 intank
stock internals/cooler etc
Jasma cat(less) back
HKS T45 S Spl turbine kit (cast manifold 50mm ext gate 4" dump, screamer)
RB20 afms
Apexi pods
Apexi Power FC
411.1 rwhp@ .7 bar
Rebuilt engine results soon..
Ceramic coated .5mm o/s CP forgies
Teflon coated skirts
Eagle Rods
King bearings
N1 pumps
HEad tickled
Port matched manifolds
Apexi 270/8.9 cams
Nismo head gasket 1.2mm
Blue printed/balanced crank (9000rpm)
Jun collar
Z32 afms
Ceramic coated exh manifolds/turbo/wastegate
Greddy Eo-1 ebc
Billet fuel rail
Sard fpr
Tomie sump baffle kit
Mines rocker cover baffle kit
Trust R intercooler
Apexi hard pipe kit
Aiming around 6-650 rwhp @1.5-1.8bar
Has already run 12.1@120mph before rebuild
https://www.sau.com.au/forums/topic/169568-500-kw-rb-26/#findComment-3133681
Once the new 1000cc injectors arrive
https://www.sau.com.au/forums/topic/169568-500-kw-rb-26/#findComment-3133748
ive got 2.7 jun stroker, 270 in/exh 10.8 cams hks t04z denso 1000cc injectors all the other bullshit along with it, hoping for around 450kw plus gas :)
after a year of building should be done next few weeks :D
Edited by 747.GTR
https://www.sau.com.au/forums/topic/169568-500-kw-rb-26/#findComment-3134119
Arrive at good reputation workshop with 1 x GTR R32, R33, R34 who cares.........
Open cheque book and say " how much for 500kw at the rear wheels?"
Expect to write a cheque for at least $30,000.00
Arrive 2 to 3 weeks later to pick up 500kw GTR
Drive off down the road smiling smuggly to yourself knowing that you will have one of the fastest cars to 50km/h on the planet. :thumbsup:
https://www.sau.com.au/forums/topic/169568-500-kw-rb-26/#findComment-3138544
    • Yep that's pretty much what I want to see. Racecars that look and sound like the Group A but with newer tech underneath to make them faster and safer. I'm sure there's enough VK-to-VN commodore, E30 BMWs and Foxbody mustangs shells around to make up a decent number of cars with hopefully a couple of sierras, rx7 and R31s in there too.
    • Contact Jessestreeter.com/Skevas Racing/JustJap for a new r34 rb gearbox or go a cd00# conversion. No point playing with unknown condition gearboxes.
    • Such a shame places like Amaroo Park have been redeveloped, smaller tracks always make for good racing. Cheers for sharing @PranK there's some good Lakeside video's too. Its so hard with older the cars as parts are so rare and everything was made for a particular chassis at that point in time. Even the V8 Supercar Blueprint era cars are all different between each chassis within a team as they learnt things and made improvements. The COTF cars between each Chassis builder is different too especially motor/oil systems/intakes. The Group A stuff is worth so much too especially chassis with good history. The only way to do it would be composite panels and similar engine drivelines to the original cars. Ford sierra running Focus RS driveline, Commodore running a short stroke LS/LT or a Falcon with coyote and a H Pattern dog box. Could use a standard ecu across all models with a Torque Map and DBW for parity which is not even used in Supercars currently. Hell a TCM is almost a full chassis car these days and the suspension is not even close to standard style in the front running cars.
    • Dashcams Australia (13/05/25) captured JDMHSE (Vic plate) being a right tosser.
    • Wish someone would start a racing series for Group A replica cars, a bit like Touring Car Masters but for 1985 onwards and not grandpa's falcon and/or Monaro. I know they race in some historic class but that's for original cars, no replicas allowed.
