Hey guys!
Currently setting up my new project.
Im on the hunt for 500kw on the rears.
Interested in knowing the following
- cams? 256?264?272?
- Turbo? 3540? T04z? Gt42?
- How Much boost?
- Injector Size? 750?850?1000cc?
Is there anyone on the forum that has 400/ 500 kw setup in their car.
Curious to know how much work is required plus the components needed.
https://www.sau.com.au/forums/topic/169568-500-kw-rb-26/
R32 GTR
Apexi PFC D-Jetro
Garrett t04Z turbo running 24psi
Apexi 53mm External Gate
Sard 700cc injectors
HKS Fuel Rail
HKS Fuel Reg
HKS Step II cams 272 272 10.2mm lift ,
HKS Valve Springs ,
HKS Valve Guides.
HKS adjustable cam wheels
Jun Oil Pump
Arias pistons with n1 rings
Pauter Conrods
608rwhp or 454 rwkw's at 24psi on Ultimate 98
https://www.sau.com.au/forums/topic/169568-500-kw-rb-26/#findComment-3133635
As per the graph, max power is 578 hp at the rear wheels. This is an improvement of 37 hp on the same dyno by fitting a 272IN cam (previous 264) and spending dyno time optimising cam timing.
Setup is:
N1 block
HKS 2.8L crank
Nismo bearings
Pauter rods
ATI crank damper
HKS nickel coated pistons
GT-RS low mounts at 25 psi
HKS bridged manifold
HKS hard piping induction kit
Apexi 136mm IC
Greddy plenum
HKS fuel rail (twin entry, single return)
HKS fuel regulator
HKS 680 injectors
Nismo intank fuel pump (direct power feed)
HKS step 2 cams (272IN, 272EX)
HKS guides, springs and retainers
HKS timing belt
HKS cam gears
HKS metal head gasket
Ported head
Trust oil pump
N1 water pump
HKS dumps, pipes and exhaust
PFC D-Jetro
Blitz dual solenoid BC
Splitfire coils
HKS Twin Power CDI
HKS twin plate clutch
GTS4 diff centres front and rear (shorter ratio than GT-R)
https://www.sau.com.au/forums/topic/169568-500-kw-rb-26/#findComment-3133643
just picked up my new GTR
1992 GTR
1000cc injectors
3X bosch fuel pumps
Standard plenum
re-ground standard cams
ARP rods
unknown pistons
T51R SPL BB turbo
AP racing Triple place clutch
Autronic computer X2
re built standard gearbox
AFR btween 12 and 13
last dyno:
631.3 ft/lb torque
578 kw at all 4
775.2 hp at all 4
that was running 2bar
dyno sheets to follow when i get scanner working
https://www.sau.com.au/forums/topic/169568-500-kw-rb-26/#findComment-3133647
Setup is:
N1 block
HKS 2.8L crank
Nismo bearings
Pauter rods
ATI crank damper
Apexi 136mm IC
Greddy plenum
HKS fuel regulator
HKS 680 injectors
HKS timing belt
HKS cam gears
Ported head
Trust oil pump
N1 water pump
PFC D-Jetro
Splitfire coils
HKS Twin Power CDI
I just made that same power with GT-RS turbo's on 21 psi with pump fuel and a light tune.
a few differences though Nissan crank, bigger cams, more headwork. but much the same. All big $$ brand name stuff, Jun Hypertune etc. It will see some more boost this week as well as some race fuel and increased timing figures.
but budget at least $25000-$30000
https://www.sau.com.au/forums/topic/169568-500-kw-rb-26/#findComment-3133679
1990 R32 GTR
Split fire coils
HKS 264/8.9 cams
OS Giken cam gears (not tuned)
Sard 850cc inj
Bosch 044 intank
stock internals/cooler etc
Jasma cat(less) back
HKS T45 S Spl turbine kit (cast manifold 50mm ext gate 4" dump, screamer)
RB20 afms
Apexi pods
Apexi Power FC
411.1 rwhp@ .7 bar
Rebuilt engine results soon..
Ceramic coated .5mm o/s CP forgies
Teflon coated skirts
Eagle Rods
King bearings
N1 pumps
HEad tickled
Port matched manifolds
Apexi 270/8.9 cams
Nismo head gasket 1.2mm
Blue printed/balanced crank (9000rpm)
Jun collar
Z32 afms
Ceramic coated exh manifolds/turbo/wastegate
Greddy Eo-1 ebc
Billet fuel rail
Sard fpr
Tomie sump baffle kit
Mines rocker cover baffle kit
Trust R intercooler
Apexi hard pipe kit
Aiming around 6-650 rwhp @1.5-1.8bar
Has already run 12.1@120mph before rebuild
https://www.sau.com.au/forums/topic/169568-500-kw-rb-26/#findComment-3133681
Once the new 1000cc injectors arrive
https://www.sau.com.au/forums/topic/169568-500-kw-rb-26/#findComment-3133748
ive got 2.7 jun stroker, 270 in/exh 10.8 cams hks t04z denso 1000cc injectors all the other bullshit along with it, hoping for around 450kw plus gas :)
after a year of building should be done next few weeks :D
Edited by 747.GTR
https://www.sau.com.au/forums/topic/169568-500-kw-rb-26/#findComment-3134119
Arrive at good reputation workshop with 1 x GTR R32, R33, R34 who cares.........
Open cheque book and say " how much for 500kw at the rear wheels?"
Expect to write a cheque for at least $30,000.00
Arrive 2 to 3 weeks later to pick up 500kw GTR
Drive off down the road smiling smuggly to yourself knowing that you will have one of the fastest cars to 50km/h on the planet. :thumbsup:
https://www.sau.com.au/forums/topic/169568-500-kw-rb-26/#findComment-3138544
    • Thanks! Will get it looked at before winter 🥶 other than that she's a mint ride love it aye
    • FWIW a lot of the local owners that do a big build tend to have cars that are perpetually broken.
    • I just got this system but haven’t installed yet I got a Moroso sealed box (defect reasons) which will be set up same as their pic The quality is high grade, the correspondence I had with the owner (former head designer for Rockford Fosgate) was unbelievable, guiding me with what I needed. Even told me not to buy some things as it could be sorted in a different way at his loss. Just a bit of a bite with the exchange rate and don’t purchase gear in 1 hit that goes over $1,000 au, lol I forgot!
    • Thanks mate for that reply. Very helpful.    it’s a 2022 400R so would most likely lose those features as you say.     I did a quick compare of a rv37 nav and heading for sale in Japan to q50 model. I’ll pop pics below. Seems  Japan spec head into top, nav unit second below it   below pic Q50 aud delivered     differences seem to be Aus delivered has a different plug top left hand side of head unit- not sure what and where it goes.   and nav unit Japanese tv37 had an extra plug put    Again I’m really not sure what each of these differences mean!       the actual plugs on a v37 and q50 screens look identical on both screens… pics below for comparing. (One screen was is a us delivered one) but should be same gps signals etc as Australia.    If it were as simple as swapping a nav unit from q50 aud delivered im interested -just want to figure out what the missing plug is for before spending big $ on a second hand part for it to not work, and I guess with the head unit, if the band expander does the job (I got a 20mHz so should get the range I’m after) so should narrow my issue down to nav unit only.  I’d love to know what the extra cable on rv37 does and if I eliminate that part what it’ll do to the setup,    and also, if I can figure out what that head unit plug difference is, what does that cable do and where does it got can it be altered or re-plugged?! Excuse my ignorance what is ACP/AA, what does that stand for? (Apple car play? Android air play)? so If I swapped head units to save using a band expander, I’d likely lose those better features to have an oem Unit operational. Better to use a band expander and retain AirPlay options and newer version of head unit     provably best to band expand it, and focus on the nav unit. th isn’t  a big deal/ would be cool to have it working  from what I can tel we use a PAL Signal and Japan uses a NTSC signal  I don’t know if there’s a co better or if the screen only reads NTSC, or if it’s the tv module that needs replacing… no big deal don’t need it but more of a curiosity thing on that!   Thanks for the info re tyre sensors, helpful and great to know.  I was reading the online manual off Japan website and it seemed to make it sound more confusing than it is  I guess a rim replacement would require the sensors to be moved to a new rim to carry that option over?!     Thanks for the info regarding diagnostic mode. I appreciate your help mate. Trying to brainstorm here to find a solution to get as much gadgets as I can working! I plan to get my local Nissan tech to have a look too who used to be at an Infiniti dealer back in the day to see if any thing they have or idea can find a soliton. But hoping anyone here has gone down the same route to make life easier!!   i guess identifying the cable/plug differences and what they do would be a great way of finding out if the units are transferable    thanks again
    • No idea about the remote start part. If the V37 nav is anything like other Nissan JDM vehicles, you can't get the factory Japanese nav working in australia, a card from a different car almost certainly won't work, those cards are usually matched to the serial number of the DCU.  You could be possibly swap out the components from a AuDM Q50 to get it working, but if this is a new model (2021+) 400R, then you will lose the newer features like ACP/AA.  That said, if you have ACP/AA, just use google maps.. I assume a band expander would be required to get the local radio stations, but don't forget the Japanese FM band is narrower than ours, so you still might not be able to receive all Australian stations. I can't see any reason the tyre pressure sensors won't work here, there is the sensor unit inside the rim and the receiver nearby in the wheel well.  I have never had to change the batteries on my 2015 Q50, so I assume they last quite a while.  A straight battery change shouldn't need them to be re-registered as they are the same unit, that should only be required if you replace a sensor with a new one.   Word of warning, if you ever go into the 'secret' diagnostics mode on the main screen, DO NOT EVER do a 'reset' in this menu, it will erase all of your model specific data in the DCU and you will need a trip to a dealer to re-program it all, which would be particularly painful being an import.  This applies to the AuDM Q50 too.
