I have noticed this pool of brown clearish sticky liquid on the passenger floor under the dash and the carpet is soaked with it and the mat has a pool mark on it. i was thinking it has something to do with the air con or heater as it seems to be on the left side of my windsreen also... weird shit! and it also smells weird.
Can anyone help me? as im strapped for cash at the moment and wanna see if i can fix it myself.
ANYONE>>>???
My car is a 95 R33.
Cheers,
Kier
https://www.sau.com.au/forums/topic/169591-pool-of-brown-fluid-can-anyone-help/
check something for me. It's brown is it? go and have a look at the coolant in your radiator and tell me what colour it is. Then get on the floor and have a look up into the dash where the heater core is and where it would leak from. see anything leaking?
lastly, are you using the plastic guard liners? water can come in if it's quite wet outside without those
Worst practical joke ever - I knew this drunk guy that thought it would be funny if he pissed in someone's car. I tell you, no one was laughing at all. that guy was dead big time. Do you have friends like that?
Edited by MANWHORE
if its brown i'd say it was your heater core. if it smells a bit musty its definitely your heater core.
even if your coolant is green, even if its fluro pink for that matter, the heater core will still leak brown. they pick up so much crap in there its not funny.
yeah guys ive had a look at other threads , i think my worst fears are realised. f**kin Car is falling apart the little c**t. o well. by the way no need to be f**kin smart c**ts aye ive never seen a coke bottle spill that much shit unless they have brought out 4L bottles recently???lol cheers mate witht the yellow ride, thanks for not being a lamo.
anyone know if it will spill more ? i am guessing it wont spill unless the climate is on more than ambient?
gtg TAFE
L8ers
gtg TAFE
L8ers
Tone your language back, absolutely no need for it.
i was being serious, as you didnt mention the size of said "pool mark" it is hard to determine how much has leaked, what size it is etc.
the easiest way to resolve your situation with little or no money spent is to bypass the heater core with some copper tubing, the hoses are just behind the passenger side cam cover, join them together to remove the core from the system - although this stops your heater from working, atleast you wont run out of coolant and over heat the car. then fix it up as per the DIY thread in the DIY section for replacing the core.
mate i came here for help aye , i dont need to be made to feel more pissed off about the situation im in with my car ok. Thanks for your help but maybe next time you "help" someone actually help them and dont belittle them. :domokun:
Cheers
gtg TAFE
L8ers
Nice attitude - Warning issued.
Next time want help, loose the attitude and post without the excessive language and you might get somewhere.
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
