Firday Nite South Side Cruise
4dirty2
 Share
  • Replies 86
was too tired for last friday night.
wouldnt mind details of this cruise, if possible.........
Im being MrMom for the rest of this week thru to sometime next week, from tomorrow arvo onwards (wife has wrist surgery), so Im sure by friday evening all I'll want to do (once Ive put kiddies and wife to bed) is get outa the house and away from the dishes/ironing etc!!!
pm please, if possible and if going ahead. Im down M/Vale way so a southern cruise (willunga / murray bridge) sounds good.
ta :)
wasnt goin to plain root was just gonna do the old ohh that rd looks good ill take that one then this one but ill make a root tonight an print a couple of copys if theres gonna b a few will pm tonight meetin place will b around mitchem possibly will pm on location after
hey send us a pm and i may be out on my first cruise!! i wont keep up with u guys though! car needs a tune running rough! but ill come!
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
