  • Replies 86
Murray bridge is heaps far
just ask Sambo
and cops galore on the way there
Not if you take the back hills routes there... You never know could turn into another midnight hills run. hehehehehe
Im keeen as long as there is some windy stuff!!! PM me the details.
whooohhoooooo that was my 400th post.... Only took me about two years!!!!!
Anyone know of any heavily worked GTR's ready for the track that are for sale??? I want to buy a track car!!! 300+RWKW....
Might be flying to bris in the next couple of days to have a look at one there.
And if anyone wants a 3" fujitsboto (or some brand like that) catback exhaust for a 33 i have my old one for sale for approx $200!!! which is freaking cheap!!!!
mind if i invite a friend to tag alone? he has a VE Clubsport 6L 6spd with 300+rwkw
(not sure if he's free but)
Sambo, want to meet me at the same spot and drive there together?
yeah, sounds good andz!
Duc u should meet up with us beforehand if it isnt too far outta your way?
dont make it to windy dan, i need to get use 2 the car first
dont be soft, hehe. hope its nice and windy Dan!
Dan also can u pm me you mobile number incase i can't get to the meet spot in time?????????? Cheers!
yeh wat else can u say havnt drvin a skyline in 9 months finaly took mine out tonight with few boys an ohhhhhhhh arrrrrrrrrrrrrrrrr forgot how ummmmmm they are
made it even btr with the teins in it umm cant wait for tommow
last week u disappeared and left Dan & I behind in the fog
was a good cruise apart from speed camera (see my essays in the wasteland section for my 2c worth) and the 180 that crashed at the top of old belair rd --> i have this on video as he was only 2 cars in front!!!
Good to see some familiar faces (andz in the 34 gtr, and Hotwire in the 33) cant wait to put my coilovers in and head out for another one!!! maybe a bit of gorge rd action this time!!!
Edited by REdgtst
there were lots of police out..... ie entry to mt barker off the freeway, upper sturt rd, and police bikes on rundle street...
anyone else back from this cruise yet????
yeah, just got back.. speed camera was super anoying!!!! still not 100% sure it was one... but with soo many people spotting the flashes... grrrrrrrrr
Man that sucks to hear, hope noone got busted! Sad I couldn't make it, was too tired after my day at work then got off my ass at about 10 tonight and serviced my car :stupid:
Chris, you able to upload that video for us to take a look at? Alternatively, anyone got any pics of the crash?
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
