Firday Nite South Side Cruise
4dirty2
 Share
  • Replies 86
softy
:thumbsup:
mind if i invite a friend to tag alone? he has a VE Clubsport 6L 6spd with 300+rwkw
(not sure if he's free but)
Sambo, want to meet me at the same spot and drive there together?
Murray bridge is heaps far
just ask Sambo
and cops galore on the way there
Not if you take the back hills routes there... You never know could turn into another midnight hills run. hehehehehe
Im keeen as long as there is some windy stuff!!! PM me the details.
whooohhoooooo that was my 400th post.... Only took me about two years!!!!!
Anyone know of any heavily worked GTR's ready for the track that are for sale??? I want to buy a track car!!! 300+RWKW....
Might be flying to bris in the next couple of days to have a look at one there.
And if anyone wants a 3" fujitsboto (or some brand like that) catback exhaust for a 33 i have my old one for sale for approx $200!!! which is freaking cheap!!!!
yeah, sounds good andz!
Duc u should meet up with us beforehand if it isnt too far outta your way?
dont make it to windy dan, i need to get use 2 the car first
dont be soft, hehe. hope its nice and windy Dan!
Dan also can u pm me you mobile number incase i can't get to the meet spot in time?????????? Cheers!
yeh wat else can u say havnt drvin a skyline in 9 months finaly took mine out tonight with few boys an ohhhhhhhh arrrrrrrrrrrrrrrrr forgot how ummmmmm they are
made it even btr with the teins in it umm cant wait for tommow
dude its a GT4 windy doesnt mater youll just want more power from not having a turbo :closedeyes:
last week u disappeared and left Dan & I behind in the fog
was a good cruise apart from speed camera (see my essays in the wasteland section for my 2c worth) and the 180 that crashed at the top of old belair rd --> i have this on video as he was only 2 cars in front!!!
Good to see some familiar faces (andz in the 34 gtr, and Hotwire in the 33) cant wait to put my coilovers in and head out for another one!!! maybe a bit of gorge rd action this time!!!
Edited by REdgtst
there were lots of police out..... ie entry to mt barker off the freeway, upper sturt rd, and police bikes on rundle street...
anyone else back from this cruise yet????
yeah, just got back.. speed camera was super anoying!!!! still not 100% sure it was one... but with soo many people spotting the flashes... grrrrrrrrr
Man that sucks to hear, hope noone got busted! Sad I couldn't make it, was too tired after my day at work then got off my ass at about 10 tonight and serviced my car :stupid:
Chris, you able to upload that video for us to take a look at? Alternatively, anyone got any pics of the crash?
 Share
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
    • @99RS4just wondering if you ever took photos of the footwell lighting / how you bypassed the controller, im keen to haver footwell lighting come on when I open the doors too
