I am F*@ken spewin,
A few days a ago I was drivin home from work on Erindale Road (Hamersley) when some nob went thru a Give way Sign and fully F@#kd up the front end of my car!!!
The engine was undamaged (besides the radiator) although a whole new front end was needed so the quote to repair was $20,000 ($5k of this was for the airbags which both deployed!).
The Insurance Coy has written the car off although the salvage on it is a mere $8k. Considering the engine is totally fine and it is a Grade 4 SII - I was really surprised that it will be salvaged for so little...
When I find out what wrecking coy has bought it, I will post it on here as the car is immaculate inside & out and guys who are searching 4 parts may be interested.
Thanks also to the guy who stopped @ the accident scene in the Black 33 to see if I was OK...I am pretty sure he is on these forums and I have seen him on a Perth Performance Cruise...
https://www.sau.com.au/forums/topic/16961-my-car-is-a-write-off/
spada let me know what insurance company it was with bro and I will find out which auction yard it is going to,
dont worry about the salvage amount its not all that important its the market that drives the price up
hmm unless it has already been auctioned and a wrecker has bought it already
mostly the salvage value comes from a salvage valuator
Hey that was me that stopped that night..... I remember as I heard the accident from my house ( I was leaving around the same time as the crash to go get fuel ). Looking at the accident I thought something like that must of happened.... I knew then it was going to be a write off looking at the damage.... As long as your ok, I guess thats the main thing. Still its very sad to see a car that you put soo much time and effort into destroyed before your eyes...
On a side note, I have been wondering .... Do you have a sister named Melissa???
Thanks for the concern guys...
b005t,
I am havin a look around now 4 a new car, as my settlement cheque is $28k I might look at adding a few extra $$ and gettin a 32 GTR.
NO_RSPECT,
Wrecker has already snapped it up, I will find out tomorrow who it is & let u know(Insurance Co was CGU)
GTS-4OrCeD,
The airbags are amazing, I was only travelling between 60-70ks and as soon as impact occurred they exploded with such pressure that there are all crack marks in the windscreen where the bags hit. The gas that inflates them nearly choked me...
MrGTST,
Thanks for stopping and seeing if I (& the car) was alright. The noise must have been pretty loud hey
Yeah my sister is Melissa, you went to Warwick SHS hey?
Nice lookin car u got there mate!
memphis,
Gearbox is good as gold. I always used Redline Oil in it...
Yep I wen't to Warwick with Melissa.... I was pretty sure you were her brother but I thought I would ask anyways :P Gee I havent spoken to Melissa since school I think.... :D
Thanks for the compliment..... I am happy with the way the car is looking these days :)
I hope you find something as nice as what you were driving as I had seen that around a few times and it looked like it was in really good nick...
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
