Has anyone here had any experience installing these onto an RB25 with an aftermarket ECU? Are there any problems or anything that is needed to be done different?
I've seacrhed around and found a few sites with instructions
http://forums.freshalloy.com/showthread.php?t=162413
http://www.takakaira.com/asp/table.asp?id=849&cat=2
Cheers
https://www.sau.com.au/forums/topic/169623-beer-rev-limiter-install/
This pin out diagram may help if haltech is plugin (wouldn't have a clue myself), if not you'll have to get the pin out diagram for the E6K. You've got no worries with an after market ECU, as the signal is going out of the ECU. Just make sure you set the ECU rev-limit above the Bee*R rev-limiter always it might cause a complete cut of ignition and fuel and I don't know what would happen there, probably nothing.
red - power
black - earth
green - ignition
yellow - rpm
white - clutch switch for anti-lag or handbrake wire for launch control.
