For sale: 1995 Nissan Skyline GTS-T
Asking Price: $13,499 as is or $12,999 without Oil Cooler and Fog Lights
Killometer's: 132,***
Manual or Automatic transmission: 5 spd Manual
Engine Type: RB25DET
Condition: Full respray end of 2006, 0 rust, 0 dents.
Rego until end of October!
Details:
The car was Complied back in 2000, I have owned it since New Years Day '06.
Modifications (That I can think of):
Series 2 Engine (not the original) with:
- Front Mount Intercooler kit,
- K & N podfilter,
- Splitfire Coil Packs,
- GFB Boost controller,
- Blitz blowoff valve,
- Dump pipe,
- Super High-Flow Cat,
- 3" Inch exhaust,
- Cold Air Induction,
- HKS ECU,
- Xtreme Performance cushioned Button Clutch
- High-flow turbo
- Oil Cooler
Suspension/Handling:
- Tanabe 'circuit' coilovers,
- Aftermarket caster rods,
- HICAS lock bar, HICAS system supplied too.
- Tein tie rods with Tie rod spacers (extra steering wheel lock)
- Front Strut Brace with Master Cyclinder Stopper
- Custom Made Braided Brake Lines
- Standard Brakes with Ferodo DS2500 Pads, and air ducting
Body: Bodykit is functional, cold air intake draws from the vent under the number plate. Kit was fitted with the intention of fitting brake ducting to the car and as such it has the necessary holes on the sideskirts to allow for cold air ducting onto the brakes at the rear. Ducting at the front fitted!
- Full car respray in factory silver,
- Trust front bar,
- 400R side skirts,
- Explosive rear bar,
- Nismo clear side indicators, standard supplied too
- GTR rear wing,
- Tinted windows,
- 17" Work Equip Rims (Super Light Weight), running 235/45s Semi Slicks at front, and 255/40s Pirelli Euphorias at rear.
- Hella Foglights
In Car:
- Moulded Gauge Holder above centre console - housing Boost, Oil Pressure, Oil Temp,
- Kenwood head unit (CD / MP3 / Radio),
- Nismo Gear Knob, standard supplied too.
- Nardi Gear Boot
- Aftermarket steering wheel fitted, standard, with air bag, supplied too
- Auto Turbo Timer
- Tracking System
Car has all power options, ABS etc, Loads of spare parts to go with the car too. Engine is in great condition, serviced regularly, runs 9 psi. Car had new water pump fitted and timing belt done at 110,000Kms. Car would make great base for a reliable circuit racer / drift car. Car has run a 1:15 around Wakefield in the wet on the current setup (rear wheels spun the whole way). Car has huge $$$ invested in parts.
Loads of spare parts to go with the car too: Including
- Spare set of rear Coil - over suspension. (Peddars springs over Koni yellow shocks)
- Dash pieces and centre console,
- Some Air Con Pieces,
- Spare Front Mount Intercooler - same size as the one on the car
- Spare side indicators,
- Air Bag Steering Wheel,
- Factory Rear Wiper,
- Coil Pack cover,
- Factory Tie Rods,
- HICAS system,
- Wiper Motor,
- Factory Gear Knob
And more!
Will sell for $12,999 without Fog Lights and Oil Cooler!
Price: $13,499 as is!
Make me a genuine offer if your interested, all offers will be considered (worst I can say is no).
Photos:
Contact: Matt on 0422 99 22 19, post here or PM me!
Edited by JDSracing
https://www.sau.com.au/forums/topic/169665-syd-1995-r33-gts-t-m-spec-modified/
  • 1 month later...
There will be another demo of what the car can do at Eastern Creek on the 4th August.
If it is sold by then the price will include the track day, I will be happy to come out with the new owner and give some feedback / instruction on where the limits of the car are and what it can do.
Make me a genuine offer if your interested, all offers will be considered.
Price Drop
Will sell the car for $16,000 as is (it needs a new brake caliper quoted at $185 from Just Jap, and the interior is stripped out (but included in the sale))
or $17,000 if I put everything back together (get a new caliper, and put the interior back together).
trust me mate, I want to sell it working, I'm just struggling to be able to get around without a licence at the moment.
But fingers crossed, I will have the caliper and be able to fix it on Saturday, then it can be test driven.
  • 3 weeks later...
Considering swap offers at the moment.
I wouldn't mind swapping for a hachi (+ cash my way) if it had the right mods.
A cage would help things along nicely...
Price is very negotiable if your a serious buyer / looking to swap
Still for sale,
Loads of spare parts to go with the too: Including
Factory Rear Wiper,
Coil Pack cover,
Factory Tie Rods,
HICAS system,
Wiper Motor,
And more!
Will sell for 14,000 without Fog Lights and Oil Cooler!
  • 3 weeks later...
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
    • Got started on the modification to make these splash plates fit over the long weekend. First the surprisingly time consuming task of swapping all the cam cap bolts to Tomei cam cap studs. I did the method of removing one bolt at a time, applying loctite to the stud, double nutting to torque as the manual described. Then carefully unlocking the nuts without disrupting the torque of the stud (and going back to re-torque a few times when it slipped). Finally applying the nut and torquing to spec. Repeat x28 Next up I went about removing the stock cam cover baffle so I could ensure it was fully clean after drilling for stud clearance.  As the blind rivets holding the baffle on were domed I used a punch to mark the center then used 4mm drill bit to carefully drill out the rivet without going too far part the baffle. As seen in other thread here is what is inside the stock baffles I decided on M4x6mm bolts to bolt the baffle plate back on with. I used a 3.3mm drill bit with some tape to mark the depth at ~8mm. Next was to tap the threads using a cheap bunnings kit M4x0.7. With the baffle removed I also drilled out the spot welds holding in the baffle plate oil returns. Unsure whether this was the best option or if I should have cut holes in the Hypertune splash plates to allow the oil drains to still function... time will tell. I then removed the the Hypertune splash plates so I could rest the cam cover on top and use a dab of grease to mark where the studs impacted the oem cam cover baffle. The most obvious spot was on the hump from the stock mesh is held. Using this hole as an anchor I bolted the oem baffle plate back into the cam cover and lined up the Hypertune splash plate. Marked the rest of the holes for the studs and drill those out too. Total 32 holes drilled and 12 threads tapped on the passenger side cam cover alone for this bolt on part that totally clears all OEM cam covers.. Drivers side next as well as some E85 safe fuel foam to fill the space behind the behind cam cover baffle plates. oh and some lock nuts for the splash plates of course.
