I've just bought an Autech Axis M35 Stagea 2004 4WD with VQ25DET 2500cc turbo motor. (See my post in the Stagea sub-forum).
Currently on the wharf in Kobe.
I think this car was the only Skyline / Stagea fitted with this motor?
Anyone know where I can go to find out about chipping, modding, etc to produce a moderate power increase?
The only mod so far is a Fujitsubo 3" exhaust.
(New to forum so sorry mods if this is posted in the wrong place)
https://www.sau.com.au/forums/topic/169683-vq25det-mods-know-any/
Which wharf? I might go down and take it for a 'test drive'... haha >_<
Yes the M35 Stagea was the only one that got the VQ25DET, and since 2002 has been played around with by a few guys like this: http://www.h4.dion.ne.jp/~lucino_s/m35_vq25det.html to varying degrees of success. The IMPUL Hi Power control unit http://www.impul.co.jp/products/HPCU.htm seems to be the ECU of choice for light tuning going by what I've seen in Japan, and as not many VQ-Ts are getting about, it's hard to find many examples of guys who do more than the usual exhaust/ECU setting/boost up/air cleaner combo of mods which usually net around 300 -350 at the wheels.
ARC do a front mount intercooler: http://www.arcinter.co.jp/arc/products/int...san/nissan.html but you could probably get a generic Ebay one and make that fit for half the cost.
Hell, theres even an Oil pan spacer http://minkara.carview.co.jp/userid/220510...8590/parts.aspx available if that kind of thing turns you on.
Actually this guy seems to have done a fair bit of work to his M35: http://minkara.carview.co.jp/userid/220510...rts.aspx?page=1 - just click through the links down where all the thumbnails are and see what he's done... 'custom' GT-RS install, full exhaust, front mount, HKS F-Con iS... couldn't find a power figure though... whould be def over 350ps @ 1.4bar.
Which wharf? I might go down and take it for a 'test drive'... haha :)
Thanks Rezz - I couldn't find the VQ25DET listed in the Impul ECU product page, and I wonder how effective an ARC intercooler would be given the limited ariflow through the large front grille?
An ECu upgrade is the same a 'chipping' a car?
It's on the 31st line down on the pricelist.
Having never looked through an Axis grille I can't say for sure either, but having said that I'm not sure if the ARC 'cooler is centre mounted or off to the side, or even in the original postion... it's not a sportscar so frontal air flow was probably pretty low on the agenda with the Axis design.
Yeah basically the same, like a full ECU unit swap to a 'pre-programmed' factory style unit with slight tweaks for air cleaner and exhaust (maybe slightly higher boost) a la IMPUL. They're only really made for retaining 'factory style' drivability and emissions while giving a noticeable albeit small increase in power/torque. The guy using the HKS F-Con iS on his M35 has the adaptor harness for the VQ25DET, so thats an extra that you'll need if you want to go down that route.
I suppose you're either going to spend quite a bit getting all your parts from Japan, or having to trailblaze a bit using locally sourced stuff and the asssociated hassles of people saying 'I'm not touching it, I don't even know what it is'...
Thanks Rezz. I found the right part on the Impul site. At over $2k it would want to make a difference - are there any specs published for this unit?
Well the guy in the h4.dion.ne.jp link got a max output of 292.9hp on the dyno with the Impul CPU, tweaking it everytime he added a new part such as bigger FMIC and switching brands of mufflers. He had a peak torque figure of 51.1kg/m (!) on his second dyno run, but he says that was a freak occurence and must've had a problem with the readout or some other fault. At any rate, the Impul ECU isn't a full computer, so they're suited to light mods only.
This chart here: http://freeplanets.jp/~skyline/Sky_Power.htm gives a good idea of the power gains to be had from the Impul ECU when installed in R32 - 34 Skylines. The furtherest 4 columns to the right go from right to left: Manufacturers Data for Power, Manufacturers Data for Torque, Tuned data for Power, Tuned data for Torque. You can see in at the top (My R34) that the Impul ECU nets about 320hp @ wheels on average up from the manufacturers claim of 280. If you clink on the links down below you can see all the dyno charts.
Btw, the Impul ECU also carries a 2 year/50,000km warranty... that would explain the price a little. :domokun:
  • 8 months later...
Sorry about digging up an old post:
@ Rezz, you seem to know a good bit about these engines - do you know is it possible to get cams, pistons, con-rods or even whole stroker-kits for these engines? Having serious difficulty in finding any information on them. I've a thread posted up here in an effort to find out some info:
http://www.skylinesaustralia.com/forums/Vq...on-t198413.html
Cheers for any help in advance! :banana:
JP
    • But we haven't even gotten to the point of talking about stateless controllers or any of the good stuff yet!
    • You guys need to take this discussion to another thread if you want to continue it, most of the last 2 pages has nothing to do with OP's questions and situation
    • And this, is just ONE major issue for closed loop control, particularly using PID. One such issue that is created right here, is integrator wind up. But you know GTSBoy, "it's just a simple PID controller"...
    • Nah. For something like boost control I wouldn't start my design with PID. I'd go with something that originates in the fuzzy logic world and use an emergency function or similar concept. PID can and does work, but at its fundamental level it is not suited to quick action. I'd be reasonably sure that the Profecs et al all transitioned to a fuzzy algorithm back in the 90s. Keep in mind also that where and when I have previously talked about using a Profec, I'm usually talking about only doing an open loop system anyway. All this talk of PID and other algorithms only comes into play when you're talking closed loop boost control, and in the context of what the OP needs and wants, we're probably actually in the realm of open loop anyway. Closed loop boost control has always bothered me, because if you sense the process value (ie the boost measurement that you want to control) in the plenum (after the throttle), then boost control to achieve a target is only desirable at WOT. When you are not WOT, you do not want the the boost to be as high as it can be (ie 100% of target). That's why you do not have the throttle at WO. You're attempting to not go as fast as you can. If the process variable is measured upstream of the throttle (ie in an RB26 plenum, or the cold side pipework in others) then yeah, sure, run the boost controller closed loop to hit a target boost there, and then the throttle does what it is supposed to do. Just for utter clarity.... an old Profec B Spec II (or whatever it is called, and I've got one, and I never look at it, so I can't remember!) and similar might have a MAP sensor, and it might show you the actual boost in the plenum (when the MAP sensor is connected to the plenum) but it does not use that value to decide what it is doing to control the boost, except to control the gating effect (where it stops holding the gate closed on the boost ramp). It's not closed loop at all. Once the gate is released, it's just the solenoid flailing away at whatever duty cycle was configured when it was set up. I'm sure that there are many people who do not understand the above points and wonder wtf is going on.
    • This has clearly gone off on quite a tangent but the suggestion was "go standalone because you probably aren't going to stop at just exhaust + a mild tune and manual boost controller", not "buy a standalone purely for a boost controller". If the scope does in fact stop creeping at an EBC then sure, buy an EVC7 or Profec or whatever else people like to run and stop there. And I have yet to see any kind of aftermarket boost control that is more complicated than a PID controller with some accounting for edge cases. Control system theory is an incredibly vast field yet somehow we always end up back at some variant of a PID controller, maybe with some work done to linearize things. I have done quite a lot, but I don't care to indulge in those pissing matches, hence posting primary sources. I deal with people quite frequently that scream and shout about how their opinion matters more because they've shipped more x or y, it doesn't change the reality of the data they're trying to disagree with. Arguing that the source material is wrong is an entirely separate point and while my experience obviously doesn't matter here I've rarely seen factory service manuals be incorrect about something. It's not some random poorly documented internal software tool that is constantly being patched to barely work. It's also not that hard to just read the Japanese and double check translations either. Especially in automotive parts most of it is loanwords anyways.
