Ok first the car is a S2 R33 GTST with front mount, 3" catback & pod. In the last couple of weeks, there have been a couple of cases where I accellerate hard and around 4-5k rpm the engine has hit a limiter.
The limiter feels like a fuel cut, if you have ever been to the speed limiter in 5th gear (~5500rpm) its a bit like that. Happened this morning in 2nd around 4-5k rpm...
Anyone know what would cause this? I'm pretty darn sure it wasnt the 7k limiter.. its a bit faster then that.
Cheers,
Ryan.
https://www.sau.com.au/forums/topic/169692-problem/
Just stock boost. It only lasted 1 second at the most... definately not the rev limiter.
I've hit speed limiter (fuel cut pretty much right?) in the non turbo and its similar to that, much quieter then a rev limiter. Like a low fast rumble..
Edited by SKY RYAN
https://www.sau.com.au/forums/topic/169692-problem/#findComment-3135940
Yeah just drove home and went to overtake someone in 2nd and it did it.. then on the freeway i droped down to 4th, then to 3rd and gave it stick and yeah it did it again...
So coilpacks eh, is it bad to drive like it is now? or can i just drive it soft..
EDIT: Wer can i get me sum coilpakz!!1!1
Edited by SKY RYAN
https://www.sau.com.au/forums/topic/169692-problem/#findComment-3136084
Talk to paul and Alistair. See what they say. I dont think it will be warranty though.
If you do want to get them from Slide, let me know as i need to order a set for for an SR aswell. We can do 1 order and try to save a bit of freight :)
Cheers
https://www.sau.com.au/forums/topic/169692-problem/#findComment-3137401
I'd be checking all your silicon joiners.. I had a hose clamp pop off (just the clamp not the silicon) and when it got to about 4k it felt like it hit a wall.. took me a bit to figure out as it wasn't like when the hose popped right off (when it popped right off it wouldn't idle and pumped HEAPS of black smoke).
https://www.sau.com.au/forums/topic/169692-problem/#findComment-3137711
the split fire coilpacks are easy as to replace, yeh you have to take off that black cover, its about 8 screws that require an allen key,
under that is the coilpacks, just have to unclip the wiring loom they are connected to and then each coilpack has 2 screw holding them down,
just take the old ones out and pope the new splitfires in, easy :P
https://www.sau.com.au/forums/topic/169692-problem/#findComment-3137807
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
    • How complicated is PID boost control? To me it really doesn't seem that difficult. I'm not disputing the core assertion (specialization can be better than general purpose solutions), I'm just saying we're 30+ years removed from the days when transistor budgets were in the thousands and we had to hem and haw about whether there's enough ECC DRAM or enough clock cycles or the interrupt handler can respond fast enough to handle another task. I really struggle to see how a Greddy Profec or an HKS EVC7 or whatever else is somehow a far superior solution to what you get in a Haltech Nexus/Elite ECU. I don't see OEMs spending time on dedicated boost control modules in any car I've ever touched. Is there value to separating out a motor controller or engine controller vs an infotainment module? Of course, those are two completely different tasks with highly divergent requirements. The reason why I cite data sheets, service manuals, etc is because as you have clearly suggested I don't know what I'm doing, can't learn how to do anything correctly, and have never actually done anything myself. So when I do offer advice to people I like to use sources that are not just based off of taking my word for it and can be independently verified by others so it's not just my misinterpretation of a primary source.
    • That's awesome, well done! Love all these older Datsun / Nissans so rare now
    • As I said, there's trade offs to jamming EVERYTHING in. Timing, resources etc, being the huge ones. Calling out the factory ECU has nothing to do with it, as it doesn't do any form of fancy boost control. It's all open loop boost control. You mention the Haltech Nexus, that's effectively two separate devices jammed into one box. What you quote about it, is proof for that. So now you've lost flexibility as a product too...   A product designed to do one thing really well, will always beat other products doing multiple things. Also, I wouldn't knock COTS stuff, you'd be surprised how many things are using it, that you're probably totally in love with As for the SpaceX comment that we're working directly with them, it's about the type of stuff we're doing. We're doing design work, and breaking world firsts. If you can't understand that I have real world hands on experience, including in very modern tech, and actually understand this stuff, then to avoid useless debates where you just won't accept fact and experience, from here on, it seems you'd be be happy I (and possibly anyone with knowledge really) not reply to your questions, or input, no matter how much help you could be given to help you, or let you learn. It seems you're happy reading your data sheets, factory service manuals, and only want people to reinforce your thoughts and points of view.
    • I don't really understand because clearly it's possible. The factory ECU is running on like a 4 MHz 16-bit processor. Modern GDI ECUs have like 200 MHz superscalar cores with floating point units too. The Haltech Nexus has two 240 MHz CPU cores. The Elite 2500 is a single 80 MHz core. Surely 20x the compute means adding some PID boost control logic isn't that complicated. I'm not saying clock speed is everything, but the requirements to add boost control to a port injection 6 cylinder ECU are really not that difficult. More I/O, more interrupt handlers, more working memory, etc isn't that crazy to figure out. SpaceX if anything shows just how far you can get arguably doing things the "wrong" way, ie x86 COTS running C++ on Linux. That is about as far away from the "correct" architecture as it gets for a real time system, but it works anyways.
