I've recently bought a Apexi FC Commander Pro cable with software package, and I used the serials and download passwords to download the software but it won't let me activate the software. It only comes up with registration fails and "check your internet connection". I know I am on internet and I am not behind a firewill or have any port routing. Im suspecting that the Apexi activation server is down! Does anybody know how to contact Apexi via email? I can't get trough on telephone :rofl:
And does anybody know if you can use Datalogit with the apexi cable and box? or do I have to have the datalogit dongle?
https://www.sau.com.au/forums/topic/169693-apexi-fc-commander-pro-activation/
datalogit i dont believe works with the apexi pro cable. i am pretty sure datalogit only works with their specific box.
fc tune should however. would be interested in letting me "borrow" the software so i can try and "make it work" >_<
hey i Actually did this recently. No Data Logic is totally Diff, requires their Hardware with 'Their' Software.
We had some issues getting it activated also. Found the link we were provided didnt work after 5pm.. ??? worked fine the next morning at 8am. strange i thought.
its the english software, i've tried to activate the software several times a day for a whole week now and still I cannot get trough and its annoying the shit out of me. I paid alot for the package and Im going to the dynos in a couple of days. It's a 12 hour drive to the nearest dyno shop so its important I have everything in order before I go =)
I'll try FC Tune beta from the rx7 forum today and see if I get contact with my pfc.
I finaly got a hold on Apexi USA via telefone, and they reset my serial number. They said it was a common bug but after a reset my activation worked after 15 minutes! So now I am a happy puppy :) FC Pro had a very extensive help file, I hope Paul makes good use on it on his excellent powerfc faq homepage :banana: thanks alot Paul33! :)
yeah the fc pro you brought is the same as the power excel fc pro, but the one you have is in english
the fc pro that got leaked is in japaense, but they both do the same thing. same as datalogit really
  • 2 years later...
Finally did you succeed in the registration?
If not I can help you.
Have you done uninstall and installation again on different computer?
fc tune should however. would be interested in letting me "borrow" the software so i can try and "make it work" :D
I can lend you the software. Which one you want? English or Japanese version.
Can you really make it work?
Can you do installation without registration?
also noticed the help for fc pro is in english
just unlocked some good info and some english translationn on some of the features
swoittttttttttttttttttt
To read the help is not enough. Can you run the program and read the help from inside?
    • I used the radium thing, makes the whole parallel assembly a lot more compact compared to any other way of doing it
    • Racetronix also sells those ethanol content sensor bypass blocks. Adapter, Flex-Fuel E85 Sensor High-Flow Bypass, In-line No Sensor (ADF-FLEX-NS): Adapters - Flex Fuel | Racetronix Ethanol content sensor are originally designed to be on the feed line. These bypass blocks are meant to be ran in the feed line and not return. The continental ethanol content sensors have a 3/8" ID and not 5/16". This is why they are ran on the return line directly in conjunction with a low threshold sampling value VS in the feed with one of these blocks.    Haha we think alike, I used both original feed/return for 8AN feed, and one of the Hicas lines as a 6AN return. I also capped off and left the other Hicas line as a spare.
    • Interesting, I haven't read about the issue with oil getting into the speedo in the cluster before. I'll have to take more notice with mine. The speedo on my R32's when I've run factory diff and tyre size have never been accurate as far as I can remember. The non Type-M GTS-t did come with 15" 5 stud wheels and smaller brakes, but that's less than 5% of them.
    • Good to hear the condenser you picked up off my brother worked all good. Do you think there could be an issue with your AC compressor itself or the clutch on it then? I don't know a lot about them so I can't really help but keen to hear what it ends up being. Keep the build thread going man, it's nice to look back on over time.
    • This is a story of my life things, I learned eventually (thanks to someone calling me out) that my enthusiasm for discussing and sharing ideas that it came across as arrogance and I'm like... WTF?!    One thing I'm pretty sure I justifiably pride myself on is knowing that everyone will have things they can teach you, and you're always going to find out that something you think you know turns out wrong - you just don't know what it is until you get there.   Just the bursting enthusiasm that comes with ADHD when you hit something that gives you dopamine dumps can come across like you think everyone else is wrong or don't matter. But yeah, I'm a software engineer by trade and also do tuning in weekends and 100% have long had a reputation for  quickly making connections when resolving problems or forming solutions that I've sometimes had to take people form a long walk from start to end to explain how I ended up where I did when it's seemed "too simple" when I've stated my initial case, and had the "WTF" type reaction when they've realised how much was actually considered haha.   My reward is that I get all the curly problems thrown at me.
