I've recently bought a Apexi FC Commander Pro cable with software package, and I used the serials and download passwords to download the software but it won't let me activate the software. It only comes up with registration fails and "check your internet connection". I know I am on internet and I am not behind a firewill or have any port routing. Im suspecting that the Apexi activation server is down! Does anybody know how to contact Apexi via email? I can't get trough on telephone :rofl:
And does anybody know if you can use Datalogit with the apexi cable and box? or do I have to have the datalogit dongle?
https://www.sau.com.au/forums/topic/169693-apexi-fc-commander-pro-activation/
datalogit i dont believe works with the apexi pro cable. i am pretty sure datalogit only works with their specific box.
fc tune should however. would be interested in letting me "borrow" the software so i can try and "make it work" >_<
hey i Actually did this recently. No Data Logic is totally Diff, requires their Hardware with 'Their' Software.
We had some issues getting it activated also. Found the link we were provided didnt work after 5pm.. ??? worked fine the next morning at 8am. strange i thought.
its the english software, i've tried to activate the software several times a day for a whole week now and still I cannot get trough and its annoying the shit out of me. I paid alot for the package and Im going to the dynos in a couple of days. It's a 12 hour drive to the nearest dyno shop so its important I have everything in order before I go =)
I'll try FC Tune beta from the rx7 forum today and see if I get contact with my pfc.
I finaly got a hold on Apexi USA via telefone, and they reset my serial number. They said it was a common bug but after a reset my activation worked after 15 minutes! So now I am a happy puppy :) FC Pro had a very extensive help file, I hope Paul makes good use on it on his excellent powerfc faq homepage :banana: thanks alot Paul33! :)
yeah the fc pro you brought is the same as the power excel fc pro, but the one you have is in english
the fc pro that got leaked is in japaense, but they both do the same thing. same as datalogit really
  • 2 years later...
Finally did you succeed in the registration?
If not I can help you.
Have you done uninstall and installation again on different computer?
fc tune should however. would be interested in letting me "borrow" the software so i can try and "make it work" :D
I can lend you the software. Which one you want? English or Japanese version.
Can you really make it work?
Can you do installation without registration?
also noticed the help for fc pro is in english
just unlocked some good info and some english translationn on some of the features
swoittttttttttttttttttt
To read the help is not enough. Can you run the program and read the help from inside?
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
    • The water pump is know to leak as well. So if the coolant is low checking that first as well as hoses.
