  • Replies 48
i thought u sold the boost controller already? why post the pic of it? ANYWAYS I WANT TT AND BOOST GAUGE. thanks - need pics 1st though. ( i know u wrote boost gauge is sold, but if buyer changes his mind i will buy it) thanks
i just sold boost gauge and apexi air filter this evening. the boost controller reason why i posted pics is coz the aftermarket air flow sensor is still attached at my car and it was pretty late at the workshop earlier and everyone was tired to do anything. so i couldnt remove the air flow sensor this evening and tomorrow morning or afternoon i'll do it.
Hippy and I met up earlier and i showed him the boost controller but he will make the purchase together with the air flow sensor. so it is not sold yet. but pretty soon it will be.
I presume it'll fit a r33 then. Sweet I'll take it if u decide to sell it to me. PLEASE SELL IT TO ME! I did shotgun first thanks. How abouts do i pay u? transfer via a/c or wat?? I've never done this b4
Originally posted by Nozila
btw in relation to the tt, ill would like to buy it off you if it aint sold yet. thanx.
Originally posted by NitRaTe
Dooky, no problem. it's sold to you.
following this reply, is it your fault or mine - im assuming its yours. thus i didnt do things without others knowing if you know what i mean.
Dooky, no big problem on my side, just on bryan's. By the way, it isnt your fault that you thought it was sold to you cause I would have thought the same if I was in your shoes, however, it is just courtesy to give the person a call before rocking up and taking the thing "off the shelf" so to speak. I was left surprised to be honest.
GTST - check your pm.
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
    • I leant out the window recently and took a picture of this new WRX. It looked real damn fine in person. It's faster around a track (stock) than a (stock) GR Yaris. It's much more practical despite being heavier. It's significantly cheaper. This gen tunes really well, much better than others. .... I think they're probably a lot better than people expect.
