but it blew up ;) I can up my boost to 30 psi and it would make a nice figure, but may have a similar outcome.
Exactly!
Ever notice too how some people always have some "buffer" excuses about the power/speed of their car, like:
"Oh I made 300rwkw, but I had a leak in the intercooler ... so I could get more power"
"I ran a 11.0 second quarter, but I was running lower boost ... so the car could go faster"
The key word is "could". You could, but didn't. When I drag raced, I was cutting 11.08 sec timeslips at best. Had another guy claim he could run a high 10sec. That guy could have, but didn't ... he popped his engine. My engine consistently put up with the abuse, and delivered the timeslips to back it up. Worse time ever was a 12.4 after a stall.
When I raced bikes at Mallala, I was running 1m17s times. Other racers said they could do a 1m17s also, but never delivered. Always some excuses about bad tyres or wrong suspension setting. If you had it right when you ran your "1m17s" you'd be consistent at it all the time.
Numbers are only serious when they're on paper and consistent.
Edited by RubyRS4
i must be showing my age but hardly funny
yep deff showing it :) i thought it was funny guy didnt really get hurt, fell on his ass for being silly.
whats there not to laugh at, hopefully some people learn some health n safty ideas from it
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
    • Dort sounds above 3k rpm are dorty 🤣 I might krinkle black the alloy 🤔
    • It makes you wonder, all these people starting to make a billet replacement head, I wonder if any have thought about trying to adapt tech from newer engines into them. You're already at the full design stage to make a billet head... Why not really spice it up and had some more modern tech into the mix too...
