i can appreciate metal drumming for the speed an precision, but its not my choice of music so that is where the appreciation ends.
i like this far more
+1. I lost interest in the whole speed thing as soon as I realised I could do it (with guitar that is). I very occasionally still use some of those techniques but I've lost most of the speed and accuracy and to be honest I not really inclined to get it back either. I get into pretty much anything - numetal
Im more into electronic stuff myself these days.
Electronic has NO limits. You can experiment and come up with sounds that no instrument can make.
Most people that arent really into music would say. ' so you like doof doof' . NO.
Electronica, dubstep, dark house, etc.
Alot of metal I can see straight through. Most normal rock is simple and boring. All been done before.
Lyrics are for the band themselves. I dont know why people have to relate to lyrics.
Really like alot of the 80s music too. Simple lyrics with the old beat machines and bass effects.
this is even better... check this guy out
no way in hell i could do that
-D
That is pretty impressive actually. precise
I'm still waiting for the day you forget to put the -D at the end.
When you do. look out
If you haven't already, I seriously recommend having a listen to an early 90's record by Depeche Mode..... Songs of faith and devotion
Got all of depeche modes stuff. Nice music. some of their remixes are really good too.
cabaret voltaire, kraftwerk, etc are my old favs.
How good is the use of the synths both musically and for effect(s) on "Songs of Faith and Devotion"..... imo genius. British/Euro synth pop/rock was probably at it's finest in the 80's.
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
    • Yes I as well would like to find out where I could get some of the seat material with the red or blue small squares in it
