Share Your Fav 'youtube'
andz
lol loving auto-tune
*expletives deleted*
while t-pain uses the autotune a lot, its a pretty damn obvious use of it for the sound effect
the thing that shits me is when you get turds like britney and ashlee simpson using it, hell, even t-pain can sing without the autotune, he just calibrates it really roughly... when they use it on girls (lip synchers i should say) like britney etc its tuned much tighter.. thing is that shit is destroying the music industry from within. i'd be outraged, if it wasnt having a spectacular blowback effect upon the listeners and the industry..
point in case.... black eyed peas
not many people know this, but back before they got that post-methamphetamine scrag fergie, they used to be one hell of an underground hiphop act.... download 'bridging the gaps' and 'behind the front' if you want to hear the black eyed peas before they sucked... as soon as they got fergie, they sold out and focused upon selling records rather than producing real good music, and for that they should be vilified and hated for the sell out capitalist cops they are... sadly, I have to confess that I did infact download their subsequent albums, and after listening to each one, I deleted that herpes infected shit off my hard drive before my entire computer caught cooties
i downloaded their latest cd, and the entire f**king thing is saccharine pop bullshit, each song uses the autotune, even in places they dont>have< to.... I felt raped from having downloaded a 60meg zip of their album, and I felt noticably dumber after having listened to that POS....
Moral of the story, autotune = shit at best, apocryphal at worst, same goes for the black eyed peas. they used to be down, now theyre just sell out clowns
-D
too late for political/religious debates we each know where we stand ;)
one does not need to believe in a deity to believe :D
Belief in ones own self is necessary for a human being to truly live free
-D
no i see it on bumper stickers all the time so there must be lots of believers :D
that white thing in the corner? is that a map of texas?
> I BELIEVE IN TEXAS! <
oh i feel the rapture-a-comin >;)
=D
Edit - srsly tho, I did 4 yrs of theology and i can appreciate the subtleties including the use of the color purple, the saying itself goes much farther than religion, its actually a psychological profile of human nature - belief of anything that is greater than ones own being inspires acts of bravery, madness, stupidity, love, dedication and cold hearted resolution....
    • The two diagrams are equivalent. The R32 one is just one sheet out of about 3 showing everything in the whole car all at once. And without knowing the functionality that occurs in the modules, they are both equally opaque.
    • 8v - 2.48ms 9v - 2.15ms 10v - 1.74ms 11v - 1.41ms 12v - 1.15ms 13v - 0.99ms 14v - 0.89ms 15v - 0.82ms 16v - 0.81ms I'm running these values on my RB20 Neo with 570cc Denso R35 stock jets and it's great. Also bought a set for my Legnum VR4, love these injectors!
    • Thanks for your reply,  Those blue/green wires running to the actuator aren't attached to anything, so I'm not sure how the central locking is still working. I will have to take a good look tomorrow, I don't have the car with me. After googling it seems like a pretty common aftermarket actuator which even uses the same green/blue wires the immobiliser required. i'll test everything tomorrow and if it's working i'll melt the solder, strip it, resolder and neaten it all up with some heat shrink. I don't have to understand it if it works hahaha I just don't want a fire/ short circuit. That R32 diagram looks more like a continuity chart? Can you make sense of this form the R34 manual? 10V is probably due to very flat battery, i'll recheck as well tomorrow, I did have to jump start it haha. Thanks again!
    • So, COM doesn't mean comms. It means common. What common itself means will depend on the type of device. For a two directional actuator (ie, one that can push and pull on the same output rod) then the common will typically just be the earth connection. There will be at least 2 other wires. If you put 12V on one of the other wires, then the actuator will push. On the other 12V wire, it will pull. Can't quite make out what is going on with the wiring of your actuator. It appears to have several wires at the actuator plug, but there only appears to be 2 wires where its loom approaches the door control module, with at least one of the others cut off. I don't know these actuators off by heart. I'd have to look at a wiring diagram for one before knowing what the wires were about, and that's despite me having to replace one in my car not all that long ago. Just not interesting enough to have dedicated memory set aside for trivia like that any more. That actuator is an aftermarket one, not the original one, which probably died and was replaced. That might require some sort of bodge job on wiring to make it work. Although nothing should justify the bodginess of the bodge job done. As to the soldering job on the door module's loom plug. Ahhahhahaha. Yes, very nasty. Again, I cant tell you what any of those wires do. You'd need to study the R34 wiring diagram (if you can find one that shows the door module). I don't think I have any. I'd have to study the R32 diagram to start to understand what mine is doing, and again, even though I've had a problem with mine for the last 25 years (where it locks the passenger door when the driver's window reaches top or bottom of travel) I'm just not interested enough to try to to work it out. So long as it's not burning down, it's fine with me. Here's the R32 GTR diagram, which, confusingly, has rear door lock actuators and window motors on it!! As you can see, unless you understand the functions of the door lock timer and the power window amplifier, you'll never be able to work out how it works just from the diagram. I don't imagine that the R34 one is any better. Hopefully an R34 aware bod can help. FWIW, the two wires that are cut and joined look like they are both power supply - so hopefully it is not fatal to join them. The 10V you measured on the cut off free end of one of them is concerning. You'd expect 12V, and it might be the reason for the bodge job joining them together.
