did you click on the wrong link Cara?
surely you didnt mean to waste everyones download limit with the first one,
and the second one wasnt much better.
This may be a repost but its an example of something that everyone would find amusing.
check out this crazy tosser.
05 yfz450 quad with a 06 zx10r ninga engine.
geared to do 230 kph at 13,000 rpm in 6th gear.
standard atv has around 50 hp at the wheels and the new and improved version has around 180 hp.
Needs a brake upgrade..
but a good laugh...
there is a bloke in alice springs that has put a 900cc road bike motor into a yamaha banshee...its awesome..
hey fella,
if you and any others didnt work it out im the guy riding that thing.
ive built it up over the last 6 months.
and Cara the second video would be alot more amusing if my ridgeback cam in after the chickens had done there bit.
little fluffy animals should be eradicated, rabbits especially.
Edited by dangerman4
