probably not new to a lot of you, this one.
i cant get enough a that sweet Mines R34 engine note!
man, doesnt that car make you wanna spend a dick load of cash on ya car.
quote from that jap dude "its so fast it'll make a dead man scream'' haha
even my missus was like daaaam!!!
Edited by Ryanrb25
