Rays Wheels - Finance
NISMO
 Share
There is a place in penrith i cant remember the name.. my friend purchased wheels from there he beat all the quotes that he previusly got .. all i remember is it is across the road from a place called Homer's Take away... if thats any help...
Thanks,
I found Homers on high street, can you remember if it was on a corner or something, cause there are no tyre/wheel places showing up on high street.
thanks
Bobby
no it is not on a corner i cant exactly remember he is acroos the road from homer's you will see like some wheels on the window .. he sells all accessories for cars. i think you have to drive there to see it for yourself....
sorry cant help any further..
no worries
if nothing else pops up i'll cruise up there this weekend.
Thanks
You're Thinking of HJC Motorsports on high street, across from the commonwealth bank & a little further down (close to where the road splits at the lights)
His name is Jun, good bloke. I'm going to see if he can source me a set of Racing Hart Wheels
That's probably HG Motorsport on the corner of High St and Woodriff St at the set of lights opposite the park.
I haven't been in there for atleast 2.5yrs simply because when I did go in there he was double the price of Nengun on basically everything except gauges. I might drop back in this week and see if he has come back to reality.
Guy's name is John So. Real nice bloke, prices are a bit on the high side for some things, but he can get a lot of cool stuff which ppl don't usually stock. You should be able to bring him down on prices, especially if you bring a car for him to perve at :thumbsup:
 Share
    • Okay, with all that being said about sloppy blowing from twins, I happily acknowledge the superiority of a single turbo setup on the RB; however, I still plan on double trouble.  I know the -9s were quite popular for some time because they seemed to meet that sweet spot between the -7s and 5s, would introducing VCAM and/or stroking to 2.8L provide the additional displacement/flow to push twins closer to the 500-600 goal?  Does it make more sense for a daily to just do an engine overhaul, slap some -7s on it and enjoy a bit more reliable power?  Has anyone driven a mine's overhauled and tuned engine?  I know they certainly don't approach the power numbers that you drag monsters do down under, but for daily street usage, I just want it to be fun and healthy.
    • Mmmm. Perhaps more correctly stated that the one turbo doesn't actually force air back down the throat of the other. All it does, and all it has to do, is be pumping a little harder than the other turbo (which is an effect of how the turbos are getting driven by the exhaust and inherent resistance to output air flow that each turbo sees up to the merge). If the turbo that is not flowing quite as much then nudges the stall line (because it gets pushed there by the higher flowing one stealing the limelight and moving its own operating point further from the stall line), then you get the behaviour described by Josh. There is no need for air to move backwards in any way. It just needs to be less air moving forwards than is required to stay to the right of the surge line.
    • GTX2860R Gen 2 is an option. No, it doesn't actually do much. The basic problem with wanting 600 whp out of the factory twin turbo setup is a few things. One is that the twin turbo piping is just so, so inefficient. The front and rear turbos are not actually working evenly. The rear turbo is always moving more air than the front. On top of this the OEM rear compressor inlet is rubber that likes to collapse causing a huge intake restriction. The merge doesn't even wait until the intercooler to happen, and it happens at a 90 degree angle. This is why you see some discussion about "turbo shuffle", where in certain conditions one turbo can actually force air to go backwards into the other compressor and stall it out, then once the other turbo recovers it stalls out the first turbo in a cycle until you do something to break out of it. The other issue is that the RB26 is just not that efficient an engine. It needs a surprising amount of ignition timing to reach MBT for a given cylinder pressure so all that time in which the cylinder is pressurizing before TDC is just wasted energy. An N54 might be around 10 degrees BTDC on a stock turbo getting into the boost. An RB26 is closer to 25 BTDC. Net effect is a turbo roughly the size of what HKS uses on the GTIII-SS (smaller than the R3/GCG Japan "GT2860-1" -7s) is only good for maybe 550 crank hp or low 400 whp while a roughly comparable turbo on an N54 can deliver something like 700 crank hp and obviously drivetrain losses are greatly reduced when you aren't burning a bunch of power on keeping a hydraulic pump + transfer case preloaded all the time. So yes, you can make a lot of power but there's a reason why people go single turbo for the numbers you're asking about. Don't forget that the RB26 can't even do a straight line pull without oil starving on the stock oil pan either. Baffles can help, but really you just need more oil capacity.
    • Yeah sure, which messenger app is it?
    • would you like to be added to the messenger group?
