Hey Guys,
The front swaybar mounts on my Series 2 R33 are old and in need of replacement.
Can someone please confirm the diameter of the standard front swaybar? I measured 22mm.
Has anyone here replaced their OEM bracket/mounts & bushes with Whiteline ones?
If so, it would be great if you could give me the Whiteline part numbers.
Cheers. :)
https://www.sau.com.au/forums/topic/169756-replacing-swaybarantiroll-bushes/
Yeah man I have done the same. :happy:
I have browsed the Whiteline catalogue but can not find anything suitable. :)
There is not even a suitable universal mount & bush kit!
I have been researching Nolathane products as well but again no results.
You might want to try them for your R32 www.redranger.com.au
Is there anyone out there who can help with R33 Swaybar bush kits???
I just bought a complete adjustable rear link pin kit for my 33. Its a heavy duty number with ball joints top and bottom and screw adjustment. It was quite expensive at around 160 dollars through repco but it does work a treat. I am not sure if they do a similar setup for the front tho.
pedders have the bushes, if you pull your link bushes out and d shakel and take it to them with your d bush, they will able to help you.
where are you located. try pedders in mitcham ask for george, he know his stuff.
if pedders still dont help,god forbid, try centreline suspension in thomastown.
cheers,
zac.
Cheers Zac!
I didn't expect to have to really search for this kind of part- I thought they would be really common! :domokun:
Hopefully Pedders can come up with something tough enough so I don't have to replace then any time soon!
Thanks again for the advice mate :)
yeah i don't wanna pay for whole new links, just need the bushes. even though i probably should've upgraded the links when i did the swaybars.
i told pedders the diameters inside and out over the phone and they were f**kall help... might try going in then :thumbsup: thanks all
Guys,
I recently bot the F & R camber kits, castor kit, subframe alignments, and swap bars from SK's suspension Group Buy. Sounds "backwards" as everyone usually goes for springs and shocks (in the form of coilovers) first but I can tell you the handing impact on my car has been amazing. Give the group buy a look.
    • Wanting to avoid this if possible but kinda looking like I may not have a choice 😭
    • Ok awesome thank you. Just wanted to have them in case I can find some and need to compare part numbers!
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
