Hey guys
I've got a few questions about my HKS Adjustable Actuator thats on the GTRS turbo. I've currently got a Profec B II installed as well.
1. Given that when the EBC is off and I give the car a hit I only see a max of 7psi does this mean the HKS actuator is set to 7psi at the moment?
2. So to tell the current boost setting of the actutor I just leave the EBC off?
3. The rod seems slightly wiggly and I can slightly rotate the it, as well as this the small pin/washer that holds the rod to the exhaust/turbine housing (pictured below) is very loose. Is this normal? If not what can I do to fix it?
4. When adjusting the rod: shorter = higher minimum boost yes? longer = lower minimum boost?
5. I assume that an EBC + the HKS actuator is the best setup? Instead of just relying on the actuator alone, where it only acts as a spring to keep the wastegate flap closed and could potentially be slowing down boost build up acceleration?
I'd really like to make the base or minimum boost around 1Bar/14.7psi as I plan to run anywhere from 18-22psi when I get a tune so I'd like the EBC to do as less work as possible in hope of achieving a flatter boost curver.
Cheers,
Andy
https://www.sau.com.au/forums/topic/169766-hks-actuator-ebc-some-questions/
wind the actuator wound in - you will increase boost.
with the ebc - yes it will be better than simply running the actuator.
i have done this with hks actuator in the past - simply wind it in so you cant actually pull it over by hand, need to use pliers because of the tension, test it with ebc off or disconnected to see what boost is at. keep winding in until you get to 1 bar.
then setup ebc accordingly.
    • 2 spots that my exhaust guy joined the 2 pipes together  Made a big difference. I'm now able to live with it. I can make it louder if I want by removing the HKS caps.
    • Hi all, considering clutch upgrade to support 1130 engine hp from 1650cc injectors on e50 at 85% duty cycle (1650 x (11.85/14.7) x 85%). Narrows down to these three as they can be converted to use gm 26 spline input shaft if I ever want to use transmission with that input shaft (orc1000f and r3c easy/cheap just change center hub; tr2cd pricier must change clutch discs). Pricing orc1000f similar to tr2cd, r3c about usd 200 pricier. Orc1000f triple plate 200mm. Tr2cd twin plate 215mm. R3c triple plate 215mm. Claimed max torque : orc 1000f 723 lbs ft; tr2cd 800 lbs ft; r3c 1100 lbs ft. Why orc1000f triple plate but claims lower max torque vs tr2cd twins? Is orc1000f underrated? Any info maxing out these clutches? Info on street/traffic driveability/pedal feel? Thank you for any info on them.
    • Some troubleshooting, connect up a timing light/gun with a proper ignition lead on coil 1. Hold the revs at 4~4500rpm and see if your timing is all over the shop, scattering off its tits. If so, there's a high chance your CAS is fked. But I read you have a Link ECU ready to go in, why not just skip all this and put that in - will make troubleshooting so much easier.
    • Misfires when the car is fully warm are generally attributed to the coils (and/or the igniter, on cars with a separate igniter). They can stop working properly when they get hot for a number of reasons. Either electric/electronic, or from thermal expansion opening up gaps and allowing HV leakage. Seeing as you have replaced the coils, that could/should rule them out. But I wouldn't always assume so. Were the coils genuine? Or is there a chance you have bought some counterfeit Chinesium shit? Then we're back onto loom connections. They can fail when warm/hot for the same reasons. Inspections, cleaning of contact surfaces, ensuring that terminals are fully inserted, etc etc, are all justified. The same (heat effects) holds true for the other electrics and their connectors. AFM & CAS, primarily. If you try that Chinesium AFM, drive it around on low load until it is properly hot, but do'nt give it more load than you have to, except when you need to see if it will still miss. I'm dead serious about the untrustworthiness of the calibration of those copy AFMs. Injectors are unlikely to get hot unless the fuel is coming back around hot. You could try squirting them with compressed air or freeze spray to cool them back down to see if they are maybe the cause.
    • Alright, all the plugs looks good. Noticed that it starts to get bad when the car is up to temp, that's when things starts to misfire hard. next to do is Injector cleaning and such. Got in touch with a shop to do work on the injectors next Monday also help on diagnosis.
