wheel nuts have nothing to do with the actual wheel hitting the caliper.
I never said they did?
But they do have everything to do with the wheel nuts coming loose after a short drive as DjeMz has stated.
Use stock wheel nuts DjeMz, quite possible the aftermarket wheel nuts are not suitable for the wheel type.
Thanks dude, ill give nissan a buz n find out how much..
Any ideas on where else i can get stock nuts?
strange! I just tried to fit a set of 34 rims then to mine..
won't fit on the front.. and will need a spacer of about 8mm (spacers are illegal btw).. Only thing I can think of is that I fitted a new set of brake pads a while ago, which maybe the increased meat in the pads pushes the caliper that much further out?
X-files??? :)
pitty your not in sydney id suggest going to tempe tyres, i got home weird ass aftermarket nuts from them that fit my wheels perfectly
any wheel shop that fits shitloads of aftermarket wheels should be able to help u out
Please tell me you are joking !!
  • 4 weeks later...
No issue with the rears at all.
I put r34gtt rims on my r32 with stock (280mm rotor) mspec calipers and they hit the inside of the front rims.
It's well documented that they won't fit straight onto r32s
I had been told I'd need a thin spacer but i didn't understand why until I tried to fit the wheels.
The issue is not that the calipers are too far out and hit the back of the spokes as I thought but that they need to be mounted further out from the centre as required for larger rotors.
8mm spacers won't leave enough thread for the full nut to screw on.
I fitted 3mm spacers to the front which gave it clearance until I found some cheap r33 calipers and rotors.
These give clearance without spacers but it would be better to fit r34gtt (310mm) brakes as the r33 (296mm) brakes give less than 1mm of clearance.
  • 4 months later...
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
