wheel nuts have nothing to do with the actual wheel hitting the caliper.
I never said they did?
But they do have everything to do with the wheel nuts coming loose after a short drive as DjeMz has stated.
Use stock wheel nuts DjeMz, quite possible the aftermarket wheel nuts are not suitable for the wheel type.
Thanks dude, ill give nissan a buz n find out how much..
Any ideas on where else i can get stock nuts?
strange! I just tried to fit a set of 34 rims then to mine..
won't fit on the front.. and will need a spacer of about 8mm (spacers are illegal btw).. Only thing I can think of is that I fitted a new set of brake pads a while ago, which maybe the increased meat in the pads pushes the caliper that much further out?
X-files??? :)
pitty your not in sydney id suggest going to tempe tyres, i got home weird ass aftermarket nuts from them that fit my wheels perfectly
any wheel shop that fits shitloads of aftermarket wheels should be able to help u out
Please tell me you are joking !!
  • 4 weeks later...
No issue with the rears at all.
I put r34gtt rims on my r32 with stock (280mm rotor) mspec calipers and they hit the inside of the front rims.
It's well documented that they won't fit straight onto r32s
I had been told I'd need a thin spacer but i didn't understand why until I tried to fit the wheels.
The issue is not that the calipers are too far out and hit the back of the spokes as I thought but that they need to be mounted further out from the centre as required for larger rotors.
8mm spacers won't leave enough thread for the full nut to screw on.
I fitted 3mm spacers to the front which gave it clearance until I found some cheap r33 calipers and rotors.
These give clearance without spacers but it would be better to fit r34gtt (310mm) brakes as the r33 (296mm) brakes give less than 1mm of clearance.
  • 4 months later...
    • Yep that's a superb price and ther is no way you will over capitalise on you investment.  As to the bracket, again just use the passenger side seat  bracket ( obviously reversed ) as a sample to reshape it and in this case, TIG it back together.
    • Thanks for that.... If only I could do something once and be happy with that, like some people do....
    • I had no transmission at all so I managed to find a big box manual gearbox from an R34 GTT for an insanely good price in EU. I converted it to push type which cost more than the transmission almost, with parts from Amayama! These engines are very strong and can put out decent power with a properly sized turbo. You can save on money from parts like pistons and rods, and invest those in the transmission and other parts. I suggest you join the RB20 Enthusiasts facebook group, plenty of info and almost daily posts there about 20DE/DET/Neo+T builds. (I hope I'm not breaking any forum rules by mentioning third party platforms, just trying to help the buddy out)
    • Yeah, having tried all of those methods including BBQ+recipro/hacksaw, I ended up buying a bush press kit under $150 that works well, like this: https://www.ebay.com.au/itm/355967727167?mkcid=16&mkevt=1&mkrid=705-154756-20017-0&ssspo=sfmmuhxgqhm&sssrc=2047675&ssuid=dJvnaZ11TB-&widget_ver=artemis&media=COPY It basically has a range of pushers and cups with threaded rods between to press out a range of large bushes. The problem with any sawing solution is minimising damage to the subframe side, although it probably needs a quick sand afterwards no matter what solution you try due to damage
    • Hi. Thanks for the answer. I do not have instagram 😄 I too considering turbo the RB20DE NEO 🙂 But i think i upgrade the gearbox first or at least buy new.
