i am buying a JJ dump/front pipe this week and am wondering what to do about the cat, i already have an aftermarket cat-back. I have been told to knock out the inside of my current cat-back to get most airfolw out of it (yes, i know it would then be illegal). Im wondering how much louder would it be (current loudness is sounds great but not loud enough to get unwanted attention)? And would doing this be the equivelent, if not better (air flow wise) than buying a hiflow cat?
https://www.sau.com.au/forums/topic/169788-knocking-out-cat-guts/
  • Replies 43
f**k I hate threads like this.
A gutted cat is only going to get you maybe 5kw more.
- Is it worth the fine ?
- Is it worth the showoff attention it attracts (ie flames) ?
- Is it worth dump raw exhaust fumes directly into the atmosphere ?
Seriously, anyone who does this on a street car deserves a slap.
Panzy's.
PUNCH IT OUT! :)
However if u drive ur car daily & ur worried about police go for a hi flow..
Cos the comment above about it blowing flames only when u gun it and back off is incorrect..
They seriously blow flames at any time! im talking to the extent where a little blue flame will pop out
changing into second gear at 2500rpm.... :banana:
If yous are worried about punching a cat out cause of the effects to the atmosphere, do not modify your car and get an aftermarket computer which is illegal in NSW as it plays with the emissions, thus effecting the atmosphere.
I think a stock cat or hi -flow cat vs a hollow cat is a very free performance gain, especially at higher hp levels.
Im sure it could be easily a 5-10kw gain at anything over 220rwkw.
Its up to the individual and thier princibles.
MY2C
Ive seen 860RWKW with a pair of 4inch cats, this was a horsepower hero dyno beast, if there was any real gain to be had, it wouldn't have had cats
"If yous are worried about punching a cat out cause of the effects to the atmosphere, do not modify your car and get an aftermarket computer which is illegal in NSW as it plays with the emissions, thus effecting the atmosphere."
Plenty of aftermarket computers can be tuned to be more fuel efficient and better emmissions than the factory 9.5:1 AFR at full load, i remember reading that 60% stock cars 5 years old would fail the drive cycle.
Dont punch your cat guts out in the first place and you have solved your own problem with the cops. Simple... why make it complicated.
I'll tell you now, if you punch them out, you are a prick, and deserve a huge fine.
If you want to know what pollution is like, move to asia and live there 24/7, then come here and tell me that you still want to punch your guts out.
not taking it out on you, but be a little more considerate and forget the 13 year olds that you will please with flames coming out your pipe.
Edited by arbess
i want flames....burn my fully sick body kit....which is already scrapping the ground.....
seriously it will stuff up the rear end making it black....shoot flames, buy a lighter...and 5kw...learn how to drive better and u wont need those 5kw....
Thx for the input, you guys love your flames, i didnt know it would blow flames, was just asking in regards to having a bit more power and also coz i dont have and wont have a spare dollar any time soon to buy a cat. Might just leave the one i got as i have a kit fitted and car is getting resprayed next week, dont wanna burn that fresh paint.
id hate to go against the crowd but going from my own personal experience i belive it makes a huge difference. even if thats true and on paper it only makes u an extra 10kw but an extra 10kw at the wheels is still pretty good. And i didnt notice a difference in top end power but i thought the way the engine felt overall was a well worth improvement. Felt more agressive and i dont belive it makes much difference to the db reading but i think personally the note is alot better. Generally speaking most skylines sound the same but with the combination of having a straight through pipe and a titanium exhuast everyone who knows my car can tell its mine just by the note. And yes it does smell pretty bad if your behind the car but im never behind my own car and yes it does pop flames but ive been told it looks awesome not becuase you can see flames coming out the end of the car but because you can see it coming towards you in a blue flame down the pipe and then watch it turn yellow once its through. I think ill stick with my decision :/
Guest
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
