its only a matter of time until you get a cop that knows what he's doing and taps your cat thats punched out and hears the "ding" then your screwed
i nearly got dicked when the cop kneeled down to look under my car, lucky he didn't see the straight pipe, after that i got myself a metal cat, f**k that fine for a joke... its just not worth it
  • Replies 43
can somone accutally confirm it IS a 10K fine!? In NSW?
quite appealing..
As said before..
I dont know many cops that rome around with a 3m wire.. that can go around 2 90 degree bends.. and would acctually be the wiser to DO IT
go for it..
we care making enough positive changes to afford a miniscule amount more..
Edited by GTS4WD
this thread has run it's course. it's a pretty bloody simple equation. yes a gutted cat will flow more than a cheap, small body cat. a good quality high flow cat will probably flow more than a gutted cat. a straight pipe will most likely flow more than them all. of these options the only legal ones are either the stock small cat, or an aftermarket highflow cat. if you want to break the law my advice is don't post about it. the power difference between a proper high flow cat, and a gutted cat has been proven time and again to be 9/10ths of bugger all.
Guest
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
