Hi Guys and Girls, I need some advice, A mate has a blown head gasket on an R33 GTS-t whats the best thing to do?? besides the obevious is there a cheaper solution?? He's had quotes around the $3500 - $5500 if the head is bent!! Has anyone had this done before with a better quote?? Any help is greatly appreciated.
Thanks in advance James.
https://www.sau.com.au/forums/topic/169844-blown-head-gasket-need-advise/
if you can remove and reinstall it yourself i would think about $400-$500 to replace the gasket and have the head decked and cleaned.
obviously that doesnt cover what ever it was that caused the fault in the first place.
headgaskets aren't that hard. time consuming but not hard. if he did it himself and the head was fine he could get away for less than $200 for a vrs kit.
maybe do it over a few days with a mate or two to help? pay them in beer and get maggot at night ha.
head gaskets are not $5000 jobs. i spoke to a mechanic, he said they sometimes cost $500 (simpler car tho). he charged $1200 i know for a headgasket job on a falcon, along with fixing up other crap. i can put u onto him but he's south syd. if your west then it probably be 1hr drive. but a very honest good mechanic
comparison of DIY. for $5500 i obtained a entirely forged bottom end, got head cleaned up, bought 1000 tools (inc. engine hoist), swapped everything over and got the car dyno tuned. i still would have had a bit of cash at the end. DIY ftw
hahahhaahahahaha $200
your forgetting a few major things
like why did the head gasket blow
u will also need a set of head bolts (as u cant reuse the old ones as nissan head bolts are torque to yeld bolts)
u need to head the head checked out (ie acid dipped ,new valve guides ,skim the head ,re-seat the valves etc)
other thing that might be needed
timing belt
idler and tensioner bearings
water pump
coolant
oil
oil filter
u cant compair the price of a head gasket repair on a falcon to a r33 skyline as a falcon dont have half the shit u have to pull off compaired to a skyline
    • Ah yes, but the part in my hand was actually painted and fitted by me! I knew any front lip was likely to be sacrificial but I've had to fix it twice already... by the time I buy a fibreglass fixing kit, sort out sandpaper blocks, buy some fibreglass filler, body bog, spend the time and effort for a 'Greg' result... a new one being $290 seems like it's the better way to go and spray that with bedliner/raptor coat and we're all pretty again.. Would have preferred it last more than a month though. Them's the breaks I suppose.
    • I find it funny that the USA is finding out all this really really weird stuff, and people from the USA are coming here treating it like gospel, yet, all the info on solving those issues is here on these forums for the last 15 odd years... Also, I know how much heat it takes to ignite the hood lining of an R33 skyline. I worked it out myself... It also took a LOT of time, and heat for it to do it... Big single, and I needed to drive the car, so retarded the timing off to "protect it". Yeah, that was a bad move for cruising on a freeway with only 15 degrees of timing on it. That was a lesson I learned around 2009. So that's over 15 odd years ago. Aligning water and oil, that's identical for any turbo engine, it's not Japanese specific. If a shop doesn't know how to make sure the core is rotated the right way, then they shouldn't be touching any turbo engine. That's not a matter of "We haven't had Skylines for that long here"...
    • Sounds like it is rotational in the driveline. CV? Tailshaft CB? Also.....didn't you just pay to have that bit painted and put on the car?
    • Yeah, when I dialled my idle down, given how much time I spent idling at the lights in traffic on my daily commute, the effect on overall fuel consumption was absolutely noticeable.
    • Emissions, fuel consumption, heat, noise, etc. most likely.
