Hi,
I have been offerd 82mm Custom CP pistons and cometic head gasket. Anyone ho has experience on boreing the cylinder from stock 78-82mm? Are the walls thick enough or DOES the kit require cylinder sleeves. Nobody has ever answered this question, and I am a little sceptic to bore 4mm over. Afraid the walls will be to thin to handle any boost.
This seller tells me its safe and no prob. to have 82m pistons fitted.
And are there any diffrence on the cylinder walls on the early and late RB20DET engines?
Thanks for any replys,
Thomas.H
www.edgeperformance.no
Edited by impultion
https://www.sau.com.au/forums/topic/169846-rb22det-safe-to-bore-4mm/
Thanks, Hi went with 83mm pistons. 5mm over. I will hear with him wht hi has done with the block.
check the rb24 thread think the guy already has pics of his bored out not sure how big he went though
http://www.skylinesaustralia.com/forums/in...20&start=20
Hi, are you sure?
This guy bored 5mm over. 83mm on his RB20 block
Murravis:
Hi Mate,
The block i have used is from a 93 r32 gts-t
The walls are still pretty thick, i got them checked when they did it and they said there fine, There is no need to sleeve the block, i was going too but the machine shop said there is no need too.
We took mine out 5mm and there fine, if tomie has made pistons to do the rb22 or rb24 conversion at a bore of 83mm they must be fine.
on another note is that your engine bay below?
Cheers
Cameron
boring out an engine and then not inserting sleeves = engine rebuild in the near future.
Well a guy i work with is an engine reconditioner by trade and he's done allot of boring in his life. He told me RB blocks are bullet proof when untouched, never seem to wear much at all (especially RB30 blocks). But once they are boared it's a very different story, much faster wear etc. using inserts will prevent this happening.
As most people will know Cast iron only has a hard outer skin (add to this nissan uses gas nitriding to harden the surface further) and the inside is very very soft. Generally the skin only has about <2mm of 'hard' surface. If you want to take of 5mm from the diamater that's a 2.5mm deep bore which is most likely the castings skin gone or very thin at best. Hence the reason people use inserts because they provide the skin again.
Machine shops will gladly do the work i'm sure but don't expect your block to last as long. personally id go for inserts especially on a bore that big.
PS: Incase i confised anyone. it's not the strength of the wall's that i'm talking about it's the hardness which will casue premature wearing of the block. You don't want that!
Edited by deant1
Hi,
Thanks for that information. Do you know of anyone ho has forged pistons and rods to the RB20DET in stock?
Thomas
    • The jack pad placement always had me scratching my head. I only have a small section to work with on both the E90 and E70 (and insert new project car here ) and I could see lining it up to be a bit of a bugger. For me, the E90 is just too low and needs small ramps and then the front centre jack point is a bit tricky to line up (it's half way down the subframe and about the size of a tennis ball, its really hard to see unless your head is on the ground), so I definitely like the idea of not having to do a multi-stage jack and just sliding these bad boys in under the sides. There's only one small point at each corner, so I can't jack AND add a stand on the same corner. Or, maybe I can and I'm too nervous to try. 😟
    • Is this not the biggest deal of all? I was hoping the whole "will slide under cars with skirts etc and lift evenly quickly with minimal fuss" was the entire point of such a device?
    • Here's Neil's car up on mine recently
    • Yeah I've got one of these, Quick Jack not Quick Lift, but your link looks like a good copy For me, it's better than no hoist, but it is definitely not as good as a hoist  It lifts the car about 60cm which is a nice working height compared to regular stands and it is only under the sills so it doesn't get in the way like regular chassis stands do.  No need to use regular stands, it has a safety lock on it. On the down side it is really heavy/unwieldy to drag into place, and you have to place it after the car is there (no option to drive the car to where the frames are. You need to try and line it up with the proper sill points which is hard as it swings up in an arc and there is surprisingly little adjustment in the distance between the rubber pads for different car lengths. Not a big deal, but in practice a jack + stands is probably quicker. Also there are hydraulic lines to each side and you need either a 240v or 12v source to power it depending on which option you have, I use 12v as I always seem to have a battery around.
    • Finally addressing my catch can and oil setup Plan is to do as much as practical without having to remove the motor or pull it apart. (no back of head to sump drain/breather or oil restrictors) First step is a set of full length baffle plates from Hypertune and a Tomei cam cap stud kit. I could probably have laser cut and bent up my own ones but this took any guess work out
