  • Replies 44
Posted Images
i;ve got the following mods
3inch Cat Back Exhaust,
Front Mounted Intercooler
Apexi pod filter
BOSCH 040 fuel pump
3 inch dump pipe
SAFC
and manage 212kwrw @ 11psi
not much difference in mods, but big difference in power
Edited by ztuned
https://www.sau.com.au/forums/topic/169854-dyno-run/page/2/#findComment-3139377
i live in kogarah..... theres not many REPUTABLE tuners.
keyword = reputable
could there be a chance his dyno scores are just low
wtf 212... man dats a big diff
ohh.... i aint goin back to him....
ohh well cash gone gotta live with the fact i blew it on a shit tuner....
guess i'll save up for a turbo and then go for a better tuner in the area..cheers guys
Edited by Zas)-(
https://www.sau.com.au/forums/topic/169854-dyno-run/page/2/#findComment-3139416
.... no need to get money back,.... i got sumthing better :P
most tuners leave off word of mouth, wait till i tell most of the bois whats happened in the area haha
i'll leave it and go for a more promising tuner later on. whatta task to find a good tuner these days
https://www.sau.com.au/forums/topic/169854-dyno-run/page/2/#findComment-3140278
Called and talked to the tuner
the tuners words are :
Your fuel pump is dumping in too much fuel as the stock engine cannot handle it. I have already put it down to almost -22 anymore is bad.
He said i need the adjustable fuel pressure regulator or else he cant tune it because the pump is dumping in WAAAAY to much fuel and flooding it.
thats why its running rich and thats why its stock afrs etc
if i had a bigger turbo then easier to handle but atm i cant... he'll charge me another 180.00 dollars for the retune afta i get a regulator.. <--
wat do u guys think
https://www.sau.com.au/forums/topic/169854-dyno-run/page/2/#findComment-3140398
that is the biggest crokc of shit ever.
The standard regulator is FINE! I run 300rwkw with mine! As long at your rail has a constant 42psi then there is nothing wrng with it.
And -22? I have taken well over 50 - 70 off some of my load points!
this guy is a f**king dipshit. I don't work for a shop, and it seems like I can tune better...
Edited by The Mafia
https://www.sau.com.au/forums/topic/169854-dyno-run/page/2/#findComment-3140609
LOL
i used " the mafias " car as an example and he said that it was more likely that ppl on skylines australia is bs.... and that most ppl here are biased ...
does anybody have an idea as to WHY? he would of said this to get a regulator and not tune it better?.
my guts telling me he wans me to come back ,giving lil power gains each time so keep coming back so he gets more cash each time.?
btw.. he supposingly is a reputable tuner in the hot fours magazines and many ppl from the hot 4's have done there cars by him
this is how i chose him as a tuner..
* nah there ppretti much standard injectors? maybe the ecu was re-mapped without me knowing?? n he cant lean the fuel out??? ( guess )?
Edited by Zas)-(
https://www.sau.com.au/forums/topic/169854-dyno-run/page/2/#findComment-3140727
wat do u guys think
this really suprises me a tuner would say this, and its almost scary that he works on cars. A FPR is exactly that, it controls the pressure of fuel in the fuel rail. Its important to understand how it works. The fuel pump pumps the fuel it hits the fuel rail and regulator, the regulator controls how much fuel pressure is going through it. Even at stock levels the stock pump is pumping more fuel than the engine needs so the FPR regulates how much fuel is needed for the motor and the extra is returned to the fuel tank. So even when you get a higher capacity pump, that extra flow doesnt go and "flood the engine", it just gets returned to the tank. When you bump the boost up, you go through more fuel to counter the increase in air, so with a bigger pump you can meet these needs, but you still wont be using the full flow of what the pump produces so once again the regulator maintains the pressure of fuel required and any extra will be returned to the tank.
A higher flowing pump wont flood the engine as long as your FPR is working, hes talking bs.
https://www.sau.com.au/forums/topic/169854-dyno-run/page/2/#findComment-3140776
exactly. You could put a 700hp pump in your tank, but the factory FPR is always only going to let the injectors see 42psi - the factory fuel pressure. Then you adjust the powerfc to suit. If this tuner is saying that your pump is too big, then he should not be tuning cars at all. And as I said before, he's only taking -22 units out? I take HEAPS more out to get my afrs up to 12.5:1
And f**k me, he wants you to put a adjustable FPR on so that he can f**k it up some more? Holy shit, he doesn't even know how a factory one works, how the f**k is he going to get a Aftermarket one working?
ahahahah what a loser. I'm biased hey? Take a print out of my Dyno run to him - tell him to shove it up his ass.
https://www.sau.com.au/forums/topic/169854-dyno-run/page/2/#findComment-3140984
... afm needs cleaning.... i'l clean it anyway just for the general purpose of doing it
lol.... well at least i know that i am on the right and that he did a shit job..
i think this guy doesnt know how to tune the stock regulator...
atm my car sometimes idles funni too :unsure:
i realli need to get her tuned again
... maybe you guys should call him up and talk to him ahahahaha ... thanks guys for telling me how it works.
although i lost 500 bucks its a lesson learnt in knowing there are shit tuners.. <--
not all just one .. I.S MOTOR SPORTS !
https://www.sau.com.au/forums/topic/169854-dyno-run/page/2/#findComment-3141289
    • The 1000ccs are side feeds but they're not currently installed, had my old factory ones in for leak testing purposes, only decided on them because front facing plenums and good top feed rail kits are out of my budget at the moment, are they really that problematic? Had a set of yellow jackets that lasted me 5 years, no real issues, only replaced them chasing this misfire issue that ended up not being ignition related 😄
    • Are those 1000cc side feeds? If so, that's part of your problem. I have 1480cc and they idle at stoich on 98RON, and all the way to E85. Also your coil packs.....
    • Update for the sake of closure   Ended up getting the intercooler piping all sorted, new plugs and yellow jacket coils, and she was idling mint until it warmed up while I was bleeding the cooling system. Found the misfire to be localised to cyl 3 by unplugging coilpacks, ran a compression test, that checked out, then decided to get a mate to check if that spark plug was firing out of the motor. Upon cranking it over, with the injectors disconnected, the car actually fired and ran on a couple cylinders and heaps of fuel came out the top of cyl 3 I'd say that injector's either spraying incorrectly or spraying far too much, which is fine as I'm planning on replacing them anyway I'm planning on making about 250kW on flex fuel, and have a set of 1000cc injectors from ozautosport, obviously overkill but I'm planning on building the motor and running more boost further down the line, do you reckon they'd be too big for a smooth idle on 98? Thanks for the replies gents, much appreciated
    • I'm confused. You said you want to "remove the clear coat from most panels" but it sounds like you are actually doing a full respray? Few random things to add -  If you chase the blistered paint with 120 grit, I can almost guarantee you'll chase it down to bare metal (that's fine). But if you paint the car from here, you'll have nice little indents where ever the blistered paint was. The new paint won't magically level out the low areas, you need to fill them. Which leads me to the main point I wanted to add, make sure the whole car is flat before you paint it. All those areas with blistered paint you sanded out, make sure to fill them and triple check they are flat with a block guide coat. I'd also check the whole car is flat with a large block and guide coat but yeah up to you if you want to go that far.
