Hey forum just need a few questions answered about timing. Ok Have a 95 r33 gtst and I am thinking of changing the poncams and the cam gears what I am wondering is how do I go about setting the timing myself already looked in the tutorials and used the search function just that there a a few minor details I need answers to.
1) When you are attaching the timing light to the first cylinder you have to take the coilpack off right, so how does it fire to make the cylinder move. Where exactly do you attach that part of the light to the spark itself or the wires in the coilpack loom and when doing this is there a tool u need to attach the spark to the now removed coilpack?
2) You have to remove the gear cover to expose the belt and shine the light on it right, and when you do that what exactly are you reading or looking for?
3)How do you retard or advance it, the car is in neutral and off then you do what turn the cam gear to a certain degree that is marked on it by way of any ordinary tool or is it more to it than that?
4)Also the tomei poncams are just a drop in or bolt in application right or do u have to adjust these too?
Just a few things I want to know before I invest in these items cause I think the mechanic is competent enuff to put the items in but I don't kno if he can set the timing and I wanted to be able to do adjust it a little on my own if I don't like the way the car responds after the upgrades. All help is appreciated thanks. Oh yeah I live in the Bahamas where we have no tuners so I have to learn it all on my own so thats why I want t o know how to adjust the timing.
https://www.sau.com.au/forums/topic/169884-setting-timing-on-my-own/
By the sound of it, in my opinion, you are not up to the task so get someone that knows what they are doing, otherwise you will stuff up big time and it will and up costing you lots more . You are confusing valve timing with ignition timing, you don't need to take any cover off to check ignition timing.
The ignition timing is easy enough to do but you will stuff up with the valve timing and may end up with a few bent valves ...
If you still insist of doing it get hold of a workshop manual and read up before you do it .
True enuff. I just wanted to know if it was a fairly medium technical level tune. Ok which do u tune with the cam gears?
Cam gears ajust valve timing ( if you have ajustable gears ). When you replace the cam belt these have to be timed with the cranc gear that drives the belt that turns the cam gears. This is the part that i think you are not up to and if you make a mistake you may stuff your cyl head . The ignition timing part you are talking about, the one you use the timing light , you should be able to learn how to check and set but you need a timing light and its done by turning the CAS .
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
