nissan skyline R34 GT-T white nismo edition 1998 5 speed manual 6 cyl 2.5litre neo spec 2 door 5 seater AZT-24W
55,000 km serviced every 5,000km have log book which serviced by bels garage reciepts all kept
recently bought 4 new tired bob jane with life time warranty
castor rods have been changed
hks super induction pod filter still with air scoop
aftermarket high volume grounding kit in engine bay
i have an apexi power f.c ecu with hand controller for this car and kept original ecu which will be supplied to buyer
orginal nismo areo kit this is the geniune kit not any after market kit
car hasnt been in any accident nrma inpection more than welcome
car has always been filled with v power 98 octane and been dyno at bel garage with power f.c and running 11psi with 175kw at the wheel have dyno papers
excedy heavy duty clutch natural
bendix ultimate brakes and have machined disc when replaced
i am the 2nd owner of this vechile in australia
nismo eyelids had been ordered from japan, have been sprayed with colour matching paint and fitted (glued)
greddy digital duel stage boost controller low is 7psi and high being 11psi
car is well maintain inside and out with no scratches or burn marks
car also has nismo clear side indicators and nismo fog lights
car is pretty much stock besides the boost controller and pod filter
rego till june
alpine stereo with 6 cd stacker in rear boot
cup holders
digital turbo timer with dual setting and other functions
window lifter set on alarm
mongoose 3 stage black wiring alarm
fatory tinted windows
nismo exshaust
dual air bags
12 inch clarion sub woofer inclosed in boot
700watt clarion amp
all power options
$25,000 ono
may swap, open to suggestion call on 0406015982
https://www.sau.com.au/forums/topic/169905-for-sale-r34-175kw-nismo/
    • Selling a genuine Nissan Skyline R33 Coupe 8-Pin Power Window Master Switch Part No. 25401-26U10 Price $300   IMPUL Gear Knob – Rare JDM Upgrade Upgrade your interior with this genuine IMPUL gear knob – a rare and stylish addition to any JDM build. Premium quality, perfect fit, and an authentic Japanese touch for your ride.  Price:$300 Nissan Skyline R33 (Series 2) Sedan Tail Lights Immaculate Condition OEM JDM S2 a pair of OEM Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state. Price:$900   Located in Melbourne (Western Suburbs) – Shipping available Australia wide at buyer’s expense. DM if you need anymore details.
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
    • LandCruiser used to get a fluid flush every 12 to 18 months.   Only because it was about that often the electric motor on the master for brake assist kept dieing and needing to come off.
