G'day guys.
Just wondering who on here is running a 26/30 in thier car, what bottom end and bolt ons you have and what power you are producing.
Just curious because I'm currently building one for my vl street/drag car, I'm looking for mid 9s.
I'm also undecided on which turbo to use, my choices are a 1000hp plain bearing ta45 76wheel and .91 rear ot a 1.00 rear t04z.
Also, I'm unsure on how far to go with the head, springs, valves etc and also cam specs.
I want something that is going to run the times at the track, whilst not being too laggy for street use.
I have a very tough jatco auto behind her which is going to sap the power a bit but it will make up for it with times.
So far my setup consists of...
26 head and standard plenum
cp forged pistons
forged rods
nitrided crank
grub screwed
o-ringed
etc
rochester 1000cc injectors
eXtm custom exhaust manifold
turbosmart 45mm gate
3.5" from turbo back
I'm also undecided on an ECU, can anyone help me there?
With this setup and say the 1.00 t04z would it be unrealistic to expect 450-500rwhp on around 24psi and pump fuel with a good head and set of cams?
What setup are you guys using on the 26/30 and what sourt of power is it producing?
cheers
brad
https://www.sau.com.au/forums/topic/169917-rb2630/
So do you have questions or do you want comparisons?
Because all you did was ask for results, and they are in the sticky :/
There arent a lot of users on here with a 26/30. And those that have *most* have posted up in the sticky thread.
Also, checking the RB26 dyno sticky will help aswell.
A few people are using T04Z's and have posted up, so obviously a bit of lateral thought application and you can come up with some expected results & parts listed
https://www.sau.com.au/forums/topic/169917-rb2630/#findComment-3140987
yeah i just wanted to know, what size cams i should be using and how far to go with the head, also it looks like ill be using the t04z with 1.00 rear so I want to know how far i have to go with the head to make 450-500rwhp comfortably on pump fuel
https://www.sau.com.au/forums/topic/169917-rb2630/#findComment-3141348
I think you would be far better off running a GT3582R at that power level , even then your not really stressing the thing . Running a larger turbo than necessary for a set power level merely lifts the on boost power range upwards . You would expect the boost enhanced torque to be happening under 3500 rpm even with the 1.06 A/R GT35 turbine housing .
Cheers A .
https://www.sau.com.au/forums/topic/169917-rb2630/#findComment-3148234
    • I totally couldn't do the whole kids taking up my life thing! 😮 I find it bad enough doing 45 hours in 4 days, and then fitting normal adulting life into the other 3 with no kids! As for my mates race cars, they're AMG C63 setup for production racing. The original is what has just been stripped and a brand new shell built. The original is then going away to have some panels straightened, then it will be put back together again. Then there's a third that will shortly head off to have a roll cage put in, then build it up too. And potentially a fourth to be built too... Oh, and he has two Renault Clio D class production cars, ha ha. And when he's not racing them in the Australians and QLD production championships, he's been racing one of Chaz Mostert's Lamborghini's in GT4. They just won GT4 at the 12 hour in the Lambo. We're pushing to finish the new AMG as it has its first round (and potentially its first shakedown/outing) in under w weeks for Round one of QPC, and that round is really the shakedown to make sure it's all good for the Bathurst 6 hour, which I'll be at too. Ha ha ha Working on my project is different to his, I slowly tinker and work ways to make things happen on a shoe string budget. Hes in a good position that he has a massive workshop full of parts and tools, ha ha. He also looks after me. When his air compressor died, he just needed it working, so bought himself a new one and gave the old to me. Sand blaster unit too, and a 20t pressing. And pretty much all the shelving in my shed too as he upgraded all of his (the stuff he gave me is the expensive black Bunnings heavy duty stuff)!   I enjoy working on his stuff. No decision paralysis, and anything that's needed parts wise is just there. Plus, then I get to be hands on at the track in real racing, not just club day stuff.
    • I know which one I'd prefer to have in my garage, and which one I'd actually drive as intended
    • Yeah mate, no probs. Just swap the email addresses?
    • I definitely agree with you there - I never click on content for cars I would never ever be able to get or compete with/against/be seen next to. Seeing a MX5 compete with a FD RX7 will make people upset though, for sure. Even in 2.5L Turbo form which is pretty grass roots. (or at least as grass roots as classic cars can be) Yes we're all classic car owners now.
    • Wonder what the cause is, but here's hoping it's nothing too serious.
