Hey guys, quick simple question..
when it feels like it, my steering suddenly goes heavy.. can be any time eg going into a round about
at slow speed, coming into a bend fast.. basically whenever the car feels like it...?
Im hoping this IS the Hicas cos my lock bar goes in this week... :)
Thanks!
Edited by Dean_HR31
could be the pump or the valve body in the top of the rack, does it do it turning in one direction? are there 'hills' you have to get over when turning the wheel (a spot of resistance that you have to push hard to get past)
This happened to me a few time on the skidpan on the weekend (and i have a lockbar) but i think
its a bit different - seemed to happen when i was spinning the wheels in 2nd so the car must have been thinking
we were doing 80 odd kms/h so the stearing goes heavy at higher speeds? does anyone know if this is true?
i always get the heavy steering issues with my hicas. light goes on...no power steering. i have the smallest of power steering leak which is causing it. topped up the fluid and it comes good after 10 mins. the hicas is sooo sensetive. have a look for the smallest.. i mean smallest of power steering leak.
Most annoying thing ever.. Goes from light to heavy..Always intermittent, and topping up fluids and recharging battery doesnt help at all. turning car off then on seems to fix it... for about 5 minutes..Cant do the hicas diagnostic either because it's too damn difficult to get started... Then suddenly it's gone and replaced by the steering wheel that jumps around, a loud clunking and the hicas light flicking, whenever your at lights with stereo or your lights on..
It sounds exactly like my 32 when the alternator was dying.
It never brought the charge warning light on but struggled to make 12.5 volts when tested with the motor running.
A new alternator and the voltage never goes below 14.2 volts and the hicas light, clunking and heavy steering never returned.
I think hicas might need more than 13 volts to work properly.
Check your output voltage and be aware that as alternators die they can work intermittently for a while so it might be 14.2 volts for at first then drop to 12.5 volts and your problem returns.
Yeh, it's ok on idle but once lights are on and it's idling it starts to do that, i've tried a new battery and that didnt help (which confused me because you'd think a fully charged battery would at least run sufficient voltages until it is flat)
Been told it could be power steering pump (which i dont agree with) so now it's either new alternator or try a capacitor or something (has expensive stezza, but problem happens even when stereo not on soo yeh)
I know this sounds bloody obvious and im sure you have checked.... Could the power steering belt just be loose/worn? It won't necessarily squeek either, as soon as it slips whilst your driving it will have the same symptoms as you have described, goes heavy all of a sudden under load, then slips, which creates friction which creates heat and then works fine for a bit before slipping again? Not saying that thats def. what it is put i'd be checking that first, its a bit of a prick to do if you still have stock FMI pipes in the way, otherwise its a 15min job.
its a real pain I get the same thing as described.. it happens by itself regulary and usually when going over 80kph on the freeway the steering goes off center.. but now often if I flick high beams on the hicas light will flash on and my stereo turns off and back on.. have intermittent issues with the steering because of it also..
but my starter motor is now making bad noises when i turn on the car so im getting that fixed next week as well as a new clutch.. thinking now maybe i should get them to check for power steering leaks and maybe replace my alternator.. hmm its a 93 r32 GTR
Edited by captain_jonno
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
