Hi guys,
Pretty much im running these mods on my r32 gtst:
high flowed turbo
full hks xuast
pod
and boosts up to around 11psi.
just feel like its down on power and could have more potential.
Not looking at spending too much for a tune, but something decent.
Anywhere around south east qld / gold coast would be great.
Cheers
Tone
it is worth remapping the standard ECU if your not going to do any more mods... so i'd suggest getting a front mount before you got it remapped, cause otherwise later down the track u'll need to remap it again.
a SAFC is a piggy back computer that modifies the reported voltage from the air flow meter. its good for some tweaking, but if you want to take full advantage of that high flow, either an aftermarket ecu or a remap is in order.
yeah would have the standard ECU.
Is it not worth while remapping the standard computer or ?
whats safc?
in that case, Mercury Motorsport and DrDrift are the only 2 i know of who have the facilities to remap the stock ecu.
yes, if you increase the boost it changes the tune. do you have a boost controller at the moment ? if not, i would get an EBC and give mercury a call. they'll set whatever boost you want and remap to suit. Also, if your gonna be putting out more power, make sure your fuel pump is up to scratch.
fyi i think a remap comes in at about $500
as the others have said the safc is a piggy back computer, it wont give you the same tune a a remap, however i dont think the total would cost as much, in saying that if you have the $$$ get the ecu re-mapped it is worth the extra dollars in the end
stuff it if ur gonna run 12psi on the standard sucker ull be fine with the nissan ECU relearning itself and save ur money and buy a full ecu eg pfc.
but if ur doin massive increases eg new turbo injects afm NOS (lol) then u should check afr and tune accordingly.
go see the guys at 101 motor cafe. From my experience there are alot of bad tuners out there and i wouldnt recommend anywhere else
Edited by r_speedfreak_r
just trying to get an idea of things,
hopefully will be slotting in a new turbo/z32/injectors/pump in the next few weeks what would you expect to pay for someone decent to tune the car, it already got the usuals and powerfc
i know matt spry is awesome from the word of mouth but seemed quite expensive ($500 to do a tidy up tune on the car as it is[tuned by APC previously])
or is that the sort of price all tuners charge
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
    • Nah, I much prefer colour matched Talking about colour matching stuff, the new/used boot lid turned up, all painted up perfectly......aaaannnndddd, it's for a power retractable hard top, not a soft top.....LOL They are now sending a boot to fit a soft top.....,  whilst frustrating, life is like that sometimes, sometimes you just need to dodge, duck, dip, dive and, ummm, dodge.
