Hi guys,
Pretty much im running these mods on my r32 gtst:
high flowed turbo
full hks xuast
pod
and boosts up to around 11psi.
just feel like its down on power and could have more potential.
Not looking at spending too much for a tune, but something decent.
Anywhere around south east qld / gold coast would be great.
Cheers
Tone
it is worth remapping the standard ECU if your not going to do any more mods... so i'd suggest getting a front mount before you got it remapped, cause otherwise later down the track u'll need to remap it again.
a SAFC is a piggy back computer that modifies the reported voltage from the air flow meter. its good for some tweaking, but if you want to take full advantage of that high flow, either an aftermarket ecu or a remap is in order.
yeah would have the standard ECU.
Is it not worth while remapping the standard computer or ?
whats safc?
in that case, Mercury Motorsport and DrDrift are the only 2 i know of who have the facilities to remap the stock ecu.
yes, if you increase the boost it changes the tune. do you have a boost controller at the moment ? if not, i would get an EBC and give mercury a call. they'll set whatever boost you want and remap to suit. Also, if your gonna be putting out more power, make sure your fuel pump is up to scratch.
fyi i think a remap comes in at about $500
as the others have said the safc is a piggy back computer, it wont give you the same tune a a remap, however i dont think the total would cost as much, in saying that if you have the $$$ get the ecu re-mapped it is worth the extra dollars in the end
stuff it if ur gonna run 12psi on the standard sucker ull be fine with the nissan ECU relearning itself and save ur money and buy a full ecu eg pfc.
but if ur doin massive increases eg new turbo injects afm NOS (lol) then u should check afr and tune accordingly.
go see the guys at 101 motor cafe. From my experience there are alot of bad tuners out there and i wouldnt recommend anywhere else
Edited by r_speedfreak_r
just trying to get an idea of things,
hopefully will be slotting in a new turbo/z32/injectors/pump in the next few weeks what would you expect to pay for someone decent to tune the car, it already got the usuals and powerfc
i know matt spry is awesome from the word of mouth but seemed quite expensive ($500 to do a tidy up tune on the car as it is[tuned by APC previously])
or is that the sort of price all tuners charge
    • Thanks everyone for the replies and suggestions. Got the seats out (hoping I could find some existing grommets but no such luck). By tapping and measuring etc. I could figure out where I could drill through if needed. But first I borrowed an inspection camera and managed to go through factory holes in the chassis rail and could see that the captive nut was holding steady which is why it could retighten. So it was indeed a stripped section of thread, so I applied downforce by levering the bolt head with a screwdriver and went slowly back and forth until it came out. Camera helped a lot cos I could monitor that the captive nut was holding tight. Now I just have one very seized main subframe nut to tackle 馃槄
    • BOVs do have a purpose, if you ever log pressure before and after the throttle body, you will see a spike pre throttle on lift off from a WOT condition. Enough to bend throttle blades / damage e-throttle motors or simple assist in blowing off cooler pipes. FWIW, the above on really applies to those running at least 2 bar of boost. OP shouldn't have an issue, on the other hand, here are some videos of my shit box over a decade ago with some succulent dose with the airbox on and off. That shit box is unrecognisable these days 馃珷
    • I've tried all different combinations of BOVs/ no BOV and stock bypass valves over the years, on gear changes the stock bypass valve seems to get the car back on boost quicker because in part the turbos wheel speed isn't being slowed down by reversion, although they have issues holding boost much over the stock setting. Most aftermarket BOVs you can adjust the spring, tighter will make it open later and close sooner, but in my experience it'll cause a bit of flutter at low load/rpm anyway. I've also got some input into this whole no bov causing turbo wear, never had an issue on any on my turbos HOWEVER, I got my R33 GTST with 200k kms on it, with from what I can see still has the original turbo, no lateral shaft play but has about 4-5mm of play in and out which to me seems like a worn thrust bearing from years (100-150k kms?) of turbo flutter running no bov, so maybe there is some truth to it in the long run. But that'll never stop me loving the Stutututu while I have the car.   OP just wants to know if he can run a atmo vented BOV with no major issues and the answer is YES, plenty of people do it, there's no harm in installing it and seeing how it runs before spending $$$ on an aftermarket ecu, last time I bought a Nistune it was $2400 for install and a tune , unsure of todays prices but you get me. Crazy money to spend just to fix the minor inconvenience of stalling that can be overcome by letting the revs come down to near idle before putting the clutch in or a little bit of throttle to avoid it. You're better off leaving the ecu and tune for after a bigger turbo/injectors have been installed to take full advantage of the tune and get your moneys worth.   Let OP have his Whoosh sound without trying to break his bank haha
    • I see you missed the rest of the conversation where they have benefits, but nothing to do with avoiding breaking turbos, which is what the aftermarket BOV made all the fan boys, tuners, and modders believe was the only purpose for them...
    • But they do so for the other reasons to have a compressor bypass. It's in the name.
