Hi guys,
Pretty much im running these mods on my r32 gtst:
high flowed turbo
full hks xuast
pod
and boosts up to around 11psi.
just feel like its down on power and could have more potential.
Not looking at spending too much for a tune, but something decent.
Anywhere around south east qld / gold coast would be great.
Cheers
Tone
it is worth remapping the standard ECU if your not going to do any more mods... so i'd suggest getting a front mount before you got it remapped, cause otherwise later down the track u'll need to remap it again.
a SAFC is a piggy back computer that modifies the reported voltage from the air flow meter. its good for some tweaking, but if you want to take full advantage of that high flow, either an aftermarket ecu or a remap is in order.
yeah would have the standard ECU.
Is it not worth while remapping the standard computer or ?
whats safc?
in that case, Mercury Motorsport and DrDrift are the only 2 i know of who have the facilities to remap the stock ecu.
yes, if you increase the boost it changes the tune. do you have a boost controller at the moment ? if not, i would get an EBC and give mercury a call. they'll set whatever boost you want and remap to suit. Also, if your gonna be putting out more power, make sure your fuel pump is up to scratch.
fyi i think a remap comes in at about $500
as the others have said the safc is a piggy back computer, it wont give you the same tune a a remap, however i dont think the total would cost as much, in saying that if you have the $$$ get the ecu re-mapped it is worth the extra dollars in the end
stuff it if ur gonna run 12psi on the standard sucker ull be fine with the nissan ECU relearning itself and save ur money and buy a full ecu eg pfc.
but if ur doin massive increases eg new turbo injects afm NOS (lol) then u should check afr and tune accordingly.
go see the guys at 101 motor cafe. From my experience there are alot of bad tuners out there and i wouldnt recommend anywhere else
Edited by r_speedfreak_r
just trying to get an idea of things,
hopefully will be slotting in a new turbo/z32/injectors/pump in the next few weeks what would you expect to pay for someone decent to tune the car, it already got the usuals and powerfc
i know matt spry is awesome from the word of mouth but seemed quite expensive ($500 to do a tidy up tune on the car as it is[tuned by APC previously])
or is that the sort of price all tuners charge
    • Thread bump, again! Although, no bad news this time. Posting for the sake of possible root cause. Basically, I rebuilt it (mostly stock), installed Haltech + sensors, had it running fine on new ECU.  Still not really understanding why it cracked pistons last time. Got to tuners, and while checking timing, noticed +-10deg of timing scatter while revving. Changed CAS, and it was rock solid. While not definitive, can't imagine seeing 20+ psi with that amount of scatter would be a good thing. Also glad I found something.   Bit more of a run down; Carried out a stock rebuild, a set of stock pistons, out of a spare bottom end. Everything stock apart from head studs and oil restrictors. (so I can pretend I didn't let the Nissan out, ha.) Armed with the measuring gear and FSM, set about doing overhaul. Oil restrictors as per oil control thread for a RB25, stock oil pump, drifting. Head drain/vent from rear of head, to passenger side of sump above oil level. Two dash 10 vent lines from drivers side of sump (unused atm) Hi octane style cam cover breather kit Splash covers over last 2 cam caps. Both breather lines from cam covers to vented to atmosphere catch can, not plumbed back into sump (wanted to see what it was actually breathing). Got it run in (did about a 1000km) no to low boost scenario, As I had questions over old ECU setup. Installed haltech +sensors for flex Retune on E85 (finding CAS Issue along the way), made 300rwkw at 20psi, out of wastegate. Did a drift day the next day (yes, it was a big weekend!) and was checking catch can throughout the day, ZERO blowby. I mean nothing. Lines from cam covers are not even wet. Done a bunch of street driving, spirited and catch can is still dry. Early days I guess, but pretty happy so far. Also now run 10w60, up from the 10w40 that I used to run. Oil pressure is significantly better, especially when hot (as you would expect)
    • Thanks buddy. I thought it was a server storage thing. 馃ぃ
    • Perfect! Thanks for this, both look like great options!
    • but deep down inside once you Skyline, you always Skyline
