Hi
This is the bin file for my R33. Can anyone who has the software to have a look at what the airflow protection is set to and if it does indead have it.
If not can somone point me to the software which will enable me to have a look at what is inside the ecu.
Its a Central 20 ecy and i think it is only maped for 0.8 bar but not sure.
PLEASE
WogsR33.zip
Edited by WogsRus
It has been a while since I have used it but the appropriate field will be obvious when you see it (I cant remember right now) and figures of 128 is limited, and 256 is maxed. I really only had a bit of a look for the theory so someone else may* have a few better answers than me
*when I say may, I mean 'will definatly' :thumbsup:
if its from a remapper joint they would be silly to increase it only a little, they would have just maxed it out
and its not controlled in boost levels, it's based around the afm signal. you should be able to run 1.3 bar no problems
so you have had a look then so essentialy i should not be hitting and R&R at all.
Esentialy what it feels like at the moment, is that below 3500 rpm the car feelslike it hits a brick wall and then takes off, like R&R on the old computer.
It started doing this since i have had y cold start strugle and no idea what it is, maybe my AFM is stuffed?
Edited by WogsRus
